Out Of Control, Copy Houston…………..
Tank
As much as I LOVE flying in helicopters, it’s like my buddy that flies for VCFD tells me all the time, “it’s the one machine where every moving part is fighting hard to leave the aircraft”.
Sleek-Jet
Helicopters are metal fatigue rotating around a common axis.
I'd like to know what happened, the tail rotor skidding across the ramp before the helo comes into view is probably a clue.
LHC Kirby
LifeTime Member
Thousands of moving parts, built and assembled by the lowest bidder.
I was thinking possibly the tail rotor clipped something out of screen too...so first thing was a buzz saw like a movie, and then went into full rodeo...
I'd have shit myself in the seat, and been trying to find cover in the ramp. Scary stuff.
RadMan
Throbbing Member
I’ve always heard the nut holding the propeller on is referred to as the “Jesus” nut, cause if that one fails you get to meet him.
Cobalt232
I spent a lot of time in R-22's (the 2 seater) in the late 80's and 90's. They are twitchy little things. That ended pretty well. Much better than doing a low G pushover and chopping off the tail or mast.
bilz
Newly Retired!😁
A different prop is definitely in order.
Glad he got out!
530RL
That’s an R22 not a 44 as the article suggests. As others have noticed, the TRGB, blade assembly and rear empennage flying into picture is certainly the first clue that something is amiss.
With just one person in an R22, they have a rear CG and hang low in the back so taking off the rear end is an easily available option.
Lastly, it would appear said pilot had not yet learned the muscle memory to roll that throttle off and got a lot more spinning around than is provided when employing the proper reaction.
Is there a disconnect, a way to disengage the powerplant from the prop? It cust seems as the the two masses were fighting in counter rotation.
Like stabbing the clutch when you hear a cars motor coming apart.
530RL
Yes,
You roll the throttle off and the rotor system disconnects from the engine via a sprag clutch. When you lose a tail rotor, you immediately roll off that throttle disengaging the engine from the rotor system which will reduce the rotational force around the mast.
A standard pre-takeoff test is to roll off the throttle and check to make sure the rotor RPM and Engine RPM needles split.
He was giving it full left pedal, for some reason it didn't respond.
The control rod was still going in and out.......
Yes, and they are not life limited.
Looks like 530RL didn't make it to the next Kamala rally.
She lost half her audience that day.
wzuber
The media can't even get a simple helicopter model # correct, something easily verifiable in minutes.........
And yet soooo many on here believe, often in a highly panicked fashion, that their " poll #'s" are remotely accurate......
That could have ended so much worse.. guy is lucky
