Cdog
- Apr 8, 2008
- 8,631
- 18,547
I built a pretty decent system on my 06 Duramax back in 2006 with a Viar on board air kit. It filled my onboard 2.5 air tank with an analog air pressure driven gauge that had twin measures for both air pressure and bag pressure. Later I added train horns with a 1/2 inch line to the horns for volume, upgraded to a 3 gallon amazon tank and viar 200psi pressure switch. The only down side to this system was needing to run air line in and out of the cab as well as the fittings/manifold the distribution to the gauge.
As I geek out looking at what's currently available it doesn't seem the industry has had any leaps and bounds in the last 15 years. It seems I'm going to have to assemble a kit as I want it which is fine by me. I plan to correct the mistakes of the past and eliminate any air hoses and manifold fittings that WILL leak in the future.
I also found this company for some mounting brackets. They appear to specialize in the air horns. I might see if I can buy their compressor and tank mounts separately.
My plans:
I already bought Firestone 2600 bag kit based on Cody from CJC's recommendations
Viair 485C (Gen. 2) Stealth Black Air Compressor 200 PSi
3 gallon tank. This is what I had on my last system. https://www.amazon.com/Vixen-Horns-...s=3+gallon+200+psi+tank&qid=1609525924&sr=8-6
Where I need some help....
I'm looking for a wireless tank pressure app or switch I can use to fill bags and know tank pressure up to 200psi. Does this exist? Firestone has one that goes up to 150 psi and Air lift has one that goes up to 120 I think. Those are pretty weak in my opinion. Do any of you know of a product/remote switch/manifold etc.. that has an app or remote switch that can display tank and bag pressure up to 200psi? Possibly from the custom car or lowrider world?
Here are links to the two options I'm disappointed by. Both fall short in a big way and are more or less just for air bags. I'll also add I have not seen any need for having independent bag pressures on my last system. I'll run a T from one source valve and fill both equally.
Ford Compatible Bolt-On Systems
Ford Compatible Bolt-On Systems. Compatible with Ford F150 and F150 Raptor truck horn systems. Train Air Horn systems include high quality trumpets and complete onboard air system. A must have for Ford trucks.
kleinn.com
My plans:
Air Compressor Kits
www.firestoneip.com
On-Board Air Compressor Systems for Air Springs | Air Lift Company
Air Lift on board air compressors and control systems.
www.airliftcompany.com
