Oil cooler questions
brendellajet
Merry Xmas RDP. Lazy day so figured I'd ask a question that I need some help with.
800hp pump gas 540 going in my Hallett 270 with a bravo 1.needs a new oil cooler. Are the combined power steering/engine oil coolers from CP any good or should I run two separate coolers? Any other options out there that I should look at?
HALLETT BOY
If you truly have 800hp , start saving for an SCX Drive , or you won’t need a cooler ...
Jonas Grumby
The Skipper
The dual from cp is fine.
brendellajet
Yeah, I know it's going to be on borrowed time.
LOBOATOMY
My buddy with a built n/a 540 would get temp creep on hard longer runs (Formula 242SS). He replace his with separate units, boy I love to buy his leftovers. These things are huge and be sure to use a thermostatic controlled block adaptor for your oil system.
spectra3279
Vaginamoney broke
I've got 2 that could be for sale. They would just need a good cleaning. With built in thermostats
