obnoxious001
Engine building character
- Dec 28, 2007
- 6,603
- 4,084
I have decided that I will pull this dusty engine apart and freshen it up, even though all parts are brand new and its never been run! From what I understand it sat in a carport area with the oil pan off, so the only reasonable thing is to carefully take it all apart, clean the block and lower end components and probably pull all the valve springs off and measure them. It's in the engine room, coming apart tomorrow. The cam sensor needs to be addressed, it's too tight against the intake. The fabricated sheet metal intake is set up for EFI, two injectors per cylinder, and it had an intercooler on top (missing throttle bodies) If I can find an intake that fits for a single Dominator, I may swap that out.
Specs are 621 cubic inches, Brodix aluminum 10.7" tall deck block, Brodix BB4 heads I believe, dry sump oil pan and pump. 10.2-1 compression, ideal for pump gas in a boat. Cam is a Bullet that was selected by the customer to run with E85 turbos.
Contact me by direct message if you have an interest in purchasing, including any customization or modifications while it's apart. It won't be apart long, once it's cleaned up it will immediately go back together as I measured all the clearances originally, so those will not have changed.
