Need stainless round rod in havasu
guest hs
Where can I get a piece that’s 7/8 diameter and about 80 inches long?
Find a used propshaft and RD has a lathe
Boat Anchor
If that is for your transom bar for the cavitation plates on the Spectra that you are fabricating, you would be better off using 1 inch diameter. On Line Metals, was having a 15% off sale. They will ship too Havasu.
guest hs
I’m not a machinist. I bought the pillow blocks from Connolly and it’s what he uses so I’m sure 7/8 is just fine.
DRYHEAT
I would think Connolly would be able to tell you where to pick up what you need, If he doesn’t stock it.
