Do you need the 2 other gaskets as well? Your location?Looking for an ignition coil and head gasket,
1989 Outboard Mercury 200
BlackMax EFI
6cyl-Twostroke
Serial Number-OC164972
Any recommendations on where I can find one?
#20 — 14697 1 — GASKET, ADAPTOR PLATE (1 required per assembly) | |||||||||||||||||||||||||||||
Just the head gasketDo you need the 2 other gaskets as well? Your location?
#27 — 16737 1 — GASKET, ADAPTOR PLATE (1 required per assembly)
#2 — 41246 — GASKET, CYLINDER HEAD (2 required per assembly) 27-41246 - Cylinder Cover Gasket [ More info ]
Unavailable
27-41246 1 - Gasket [ More info ]
Unavailable
27-41247T01 - Head Gasket [ More info ]
$67.75
Available to Order: Usually ships within 10 days.
18-3862 - Head Gasket 27-41247T01 [ More info ]
$42.99 $39.05
2 In Stock.
#18 — 7370A13 — IGNITION COIL (6 required per assembly)
339-7370A13 - Ignition Coil [ More info ]
Unavailable
339-832757A 4 - Ignition Coil [ More info ]
$116.75
18-5186 - Ignition Coil 339-7370A13 [ More info ]
$61.99 $57.13
10+ In Stock.
Mercury (200 Xri (Efi) (V-6)) Engine Components
www.marineengine.com
Think they are both closed now but as a suggestion to call using at minimum the Sierra part numbers could be,Just the head gasket
We’re in Fort Mohave until tomorrow looking to pick up today. (I know it’s a long shot)
