MSD 6 al SERIES FUSE SIZE
wettrthebettr
Does anyone know what the Fuse size would be for a MSD 6 al ?
6000 RPM's would be the max with a limit chip
wettrthebettr
MSDTECH they said that you can add a 30A fuse INLINE on the heavy red 12V Power Lead between the battery and the box.
But Not Required
wet hull
My MSD 6 is on a 30 amp fuse for power. I have a 6000 rpm chip in the box
wettrthebettr
My 30amp fuse did not keep my MSD Blaster 2 Ignition Coil from Exploding last evening.
It was all my stupid fault, I was trouble shooting my Bennett system out for about 1 1/2 hours with the key on and my coil Blew up.
What a mess, lt was a good thing I was not near it. 50 bucks down the drain.
28Eliminator
View attachment 773752 View attachment 773753
Damn!!! I have the same setup, but I don’t recall putting a fuse in line for the box... now I’ll have to check. I’m on borrowed for the MSD box.. 8 years and over 400 hours, still running.. fingers crossed [emoji1694]
Carlson-jet
Not Giving A Fuck Is An Art
A resistor is needed in some applications on a standard coil.
I've never had a coil fail like that. Strange.
wettrthebettr
I called MSD they told me that they get phone calls all the time from people leaving the ignition key on for hours.
I put an on and off switch and a red light on the small red wire that goes to the ignition now. I will not do that stupid thing again.
Carlson-jet
That's why I go with Accell..LOL
I kid.. :D
In the "Old days" One just burned up the points leaving the key on. :D
