fishing fool
- Dec 21, 2007
- 5,647
- 6,275
Talk me out of getting a 24' motorhome with a Ford V10........ Only towing inclosed with rzr.
I had 2 V10 motorhomes. Both ran great. Towed my boat everywhereTalk me out of getting a 24' motorhome with a Ford V10........ Only towing inclosed with rzr.
I'm looking at 2017 and newer..... So I should I be good.Does it come with a spark plug catcher?
This is a good article on the better years.
Ford V10 years to avoid — most common problems | REREV
Learn about the Ford V10 models with known issues to make an informed decision when purchasing a used Ford V10 vehicle.rerev.com
I had a Hurricane with the same set-up and it also ran great, cheap oil changes and I ran it hard towing a 100% when used it, I can remember a time when the wasn't something behind it.I had 2 V10 motorhomes. Both ran great. Towed my boat everywhere
I had the Banks kit on one and it was flawless
6.9mpg. That was my average on my latest 4,000 mile road trip. 2013 V10 with Bank intake kit.
Just the wife and myself. With a 20' enclosed trailer if there is bad weather (wind) the group and go in there and hang out. The wife will be able to drive a smaller one herself to visit the grandkids.The only thing I would talk you out of is a 24' motorhome. Why so short? My parents have probably close to 100k miles on two V10 motorhomes over the past decade and never a single drivetrain issue.
Is the short motorhome rated for more than 5k? Most of the gassers have a very weak tow rating (on paper).I was looking at Sprinter vans until I found out they only tow 5000#. I figure trailer and SXS will be that much alone.
We had that same issue on a 99 Expedition. Shorted out the fuse box and engaged 4Lo full time. We were in Utah on a ski trip that got extended a couple of days, so it worked out OK.I have an 03 V10 Excursion, I believe the faulty threaded blocks/heads ceased production in November of 02. You can pull a block number off the front of the motor to see, specifically, when the motor was built. Maybe a VIN could also do the same?
We have 130k on ours. No issues whatsoever other than a random stall caused by a water damaged fuel relay that is soldered onto the interior fuse box. It's not easily replaced. Either you pull the fuse box and have it rebuilt, or you rewire around the relay.
The water damages is from a weak ass windshield seal. Somehow water finds its way down the harness onto the fuse block. I just went thru this fiasco again. I had the windshield replaced a year or two ago and I foolishly washed the truck. Just the single wash took out the fuse box again.
There are videos on how to seal the windshield properly.
So just be sure the year motorhome you are buying does not have the same windshield seal issue. It was a common problem in the vans and Explorers - so much so that it created a niche market for water damaged rebuilt fuse boxes.
And Alamo lake, Williams with a bucket list trip to pink coral sand dunes. Shea Rd in parker over night trips to the beach. I might even take it to your house in Cali just to say Hi.....Are you gonna leave your house and go camp 4 miles away at the concrete camp?
24’ with a v10 will have zero issues towing or Mpg. No need to talk you out of it.Talk me out of getting a 24' motorhome with a Ford V10........ Only towing inclosed with rzr.
Did you sell the trailer?The diesels don’t get much better mpg. They. Just don’t struggle too hard. But with a 20’ enclosed or flat trailer and a rzr even the boat is no problem for the gas motors.
Hell no! I pulled it from the market, will repost in a month or two. Market is soft as can be right now. Total buyers marketDid you sell the trailer?
Mine is a 22' classC, v10. Has 8k hitch.Is the short motorhome rated for more than 5k? Most of the gassers have a very weak tow rating (on paper).
My does the good job with the v10 350 hp 7.3L 7500 hitch and 500 pounds tongue weight 6 speed transmission pulls strong has tow haul mode it’s a 23 yr rv.Talk me out of getting a 24' motorhome with a Ford V10........ Only towing inclosed with rzr
What’s in there? I want to buy an enclosed and pull the rzr and bikes. I’m kind of scared but maybe I shouldn’t be. I would love a big enclosed like that. Might not be able to afford it but I’d love it the sameI've had 2 now, no issues with either. Only real drawback is they only rate the front engine A class coaches at 5k towing capacity. The towing police may be upset to see you towing more than that, but I have had no issues. Won't be the fastest up the grades, but it will get there. Make sure you have brakes on the trailer and a brake controller in the coach.
This is the motorhome I am looking at.. 450 chassisMy does the good job with the v10 pulls strong has tow haul mode it’s a 23 yr rv . Some class c are built on F450 or the F350 chassis’s the F450 are rated little higher capacity. View attachment 1465757
My has the v10 7.3L 350 hp 6 speed transmission tow haul mode 7500 hitch , 500 capacity tongue weightThis is the motorhome I am looking at.. 450 chassis
Those small Class C’s would be perfect for you guys.And Alamo lake, Williams with a bucket list trip to pink coral sand dunes. Shea Rd in parker over night trips to the beach. I might even take it to your house in Cali just to say Hi.....
ps...... I will get a loan with thr RV loan guy.
V-10's are 6.8L, what year is yours?My has the v10 7.3L 350 hp 6 speed transmission tow haul mode 7500 hitch , 500 capacity tongue weight
Small fresh & black/gray tanks. Smaller fuel tank. And most class C’s don’t have leveling jacks, just something to think about.Pay attention to your fresh water tank capacity! Class C rigs doesn’t have large tanks
you might have to add a tank to the enclosed trailer then pump it into the rig
What’s in there? I want to buy an enclosed and pull the rzr and bikes. I’m kind of scared but maybe I shouldn’t be. I would love a big enclosed like that. Might not be able to afford it but I’d love it the same View attachment 1465759
I've got an '08. Problem free... except for starters. Exhaust heats up solenoids on the starter.. After 3 starters I made a shield and no problems since. Pretty much all the 50k milage has been towing boat or toad. No spark plug issue unless you have to change them...lol..I'm looking at 2017 and newer..... So I should I be good.
