jetboatperformance
- Jan 1, 2008
- 8,753
- 19,307
We have a Hot point over stove Micro wave that keeps burning out range hood bulbs , latest incandescent only lasted a week ? power surges ?
Thanks Joe , just the type of "help" I was looking forIncandescent?
What's that?
I have the same issue with a samsung microwave. I don't know why, but the digital clock is even slow, so I don't worry about it and use different lights.We have a Hot point over stove Micro wave that keeps burning out range hood bulbs , latest incandescent only lasted a week ? power surges ?
Maybe was replaced with the wrong voltage bulb (12volts/24volts).We have a Hot point over stove Micro wave that keeps burning out range hood bulbs , latest incandescent only lasted a week ? power surges ?
Good call Checked that I'm starting to think it may want halogens vs incandescentMaybe was replaced with the wrong voltage bulb (12volts/24volts).
Contraband!Incandescent?
What's that?
Thanks for the thought I will probe the source today to check voltage I'm thinking I'll try a pair halogens (vs LEDs) because it has a "dim" or high /low settingOther than the norm, like dirty lamp contacts, If there's an exhaust fan built into the over the stove unit, the vibration from the fan could be the culprit. I'd recommend buying Rough Service Light Bulbs, they're made to withstand vibration. Vibration will kill normal bulbs. Maybe you should check and clean the exhaust fan as well ?
Check and clean the sockets if dirty, check lamp socket voltage, but with the microwave working fine, I suspect there's not a problem with supply voltage, but could be in the dimmer circuit ? Especially if both lamps are failing at the same time.
OK, I didn't realize your hood was designed for PAR style lamps. In that case, they make PAR 20, Appliances Range Hood Lights in Incandescent, Halogen and LED.Thanks for the thought I will probe the source today to check voltage I'm thinking I'll try a pair halogens (vs LEDs) because it has a "dim" or high /low setting
Headed to Ace today , all these are inexpensive I seldom use the lights but the Boss/Head Sammich maker doesOK, I didn't realize your hood was designed for PAR style lamps. In that case, they make PAR 20, Appliances Range Hood Lights in Incandescent, Halogen and LED.
Halogen's a good choice, but can oscillate when dimmed down to far, that will kill them. Since LED's Achilles heal is heat, I think I'd stick with Halogen or Incandescent "Range Hood" (Rough Service) PAR lamps.
Oh, so not PAR style lamps --- good luckWhat a Woman, got her the LEDs and she went to work on the install fingers crossed
