[WTS] Mercury 300 drag motor
dp70
SOLD
Mercury Racing 300 Drag (2.5) / 315 hp (compression at 167-170 all cylinders)
- 1997 (put on boat in 2000)
- 20" Mid section (had a 15" originally, previous owner changed to work better on the boat it is on Mach 22)
- Sportmaster lower - incl. prop
- Brucato PCU with steamwheel (mounted inside boay on transom, never mounted on motor or wet
- New reed valves and injectors near same time when Brucato unit was added
- Will include trim pump and fuel pump - hydraulic steering not included, staying wwith boat
- Alien Cowl - in near perfect condition
- As stated by previous owner (I just bought boat and I am re-powering) Motor was rebuilt approx 5 yrs ago, incl. new pistons, rings, bearings, machine work by Rucks.
He only Since used couple times a year due to work schedule so not a lot of run time (approx. 40 hrs since rebuild)
- I had motor inspected, pulled heads looked good, re-installed with new gaskets, pulled injectors and had them cleaned and flow tested, all good. (have report)
Located in Lake Havasu City AZ - local pick up or can put in Mercury shipping crate for shipping.
Currently still on boat but will be pulling soon for re-power.
call/text 928-412-4006 Danny
asking $9,500 obo
lenmann
What are your plans for the re-power?
Typically how long do those run before needing to be rebuilt?
dp70
This is a low hr motor in great shape ready to go on your boat
