Cgrohe223
- Jul 23, 2015
- 1,150
- 571
I can tell you that the 225 ProMax was the most expensive motor I've ever owned. Gives me the willies when I see one.
Full obstruction of an injector took out the 4, 5 and 6 pistons. Replaced those, the port head and all lines and hoses. Had to send the block LA sleeve for resleeve and hone. All injectors were sent to Brucato cleaned and tested. About $8k. # highstrungmotorproblems. LolWhat happened?
Was like a new motor when we were done... then the Daytona came up for sale and we jumped ship, literally.
Well I'm going to give the boat a look hopefully Saturday and look over everything
At 409 hours its not a spring chicken but it depends on how its been treated, fuel/oil quality, rpm history. If it were me I would try to get owner to pay for a leak down test by a qualified shop. Overall that's a good looking machine which probably says the owner has taken good care of her.
It's just broke in!!!!
If you're going to be looking at it in Martinez and need a place to crash, hit me up.....
There's a nicer one for sale in Martinez that has a 300xs on it. He wants $19,000.
I might have to refer my cousin to this one.His name is Jason 619-922-9559
I looked up hours on them and some have got over 2000 hours which is crazy but j know it's getting tired around that time but good know. Is it hard to service the oil injection in these and does it have a tank that you dump the oil into
I have not owned one but I believe the weak point is a plastic wheel that meters the oil flow. As Wicky said many have removed the system and just pre-mix. I remember there is a block-off cover you can buy or possibly make your own if you remove it. Just going off stuff I have read about them.
Nice boat but little steep on the wallet right now haha I was close to buying the red 82 from maxed out but owner was stuck at 18,700
Jason's bottom dollar was 18k. Not a penny less. Engine only has like 60 hours on it. I would have bought it but it was more then I had and I couldn't do the pink and purple. + the $6000 in gel, $2500 interior.
If you can get a daytona with a 300xs on it for $19k i would look at that one first. The newer daytonas have had some transom issues, check it out good. Also find out if it is glass or Kevlar lay up, worth ore if it's Kevlar but very prone to stress cracks because the hull is only 500 pounds. With a 300 your looking at 105 or so, daytonas really come to life with the 3 liter motors. With 400 plus hours a big bill is around the corner, if you go into knowing that and are ready for it financially then go for it. Also it's important to know what lower it has on it.
I'll sell mine when I get it done, still sorting out lots of issues from sitting for 10 years from but making progress. 84mph and climbing.
Next up will be a 22 with twins.
I don't have a pro-max but my 93' 2.5L Merc had oil injection which I removed. The oil injection worked fine. It's the horror stories you hear about it failing that are scary. The fiber/plastic gear on the crank that you don't see, that you can't replace with out a complete tear down is what fails. That and the pump shaft being steal doesn't help.
The system varies the amount of oil that is injected by RPM. It has 2 tanks, one remote tank under your rear deck typically that holds the bulk of the oil. Like 2 gallons I think. Then a small tank under the engine cover. Neither tank is vented. It uses crank case pressure to pump oil from the remote tank up the under cowl tank that feeds the pump.
There are a couple of sensors one for the pump and another on the under cowl tank for low volume.
By the time the sensor goes off that says the pump is not working it's usually to late and the damage is done and your rebuilding the engine. That is why guys remove the oil injection and premix.
So is this boat not a good thing to do or should it be good and remove the oil injection. Kinda has me scared to even get it
But others just said 400 hours isn't much so which one is It haha
Basically getting an nearly new engine with a free boat, that's a great deal!
I currently have a 2001 22 Daytona with twin 225 Pro Maxs. This is at least my tenth twin engine cat I have owned and I will say it may not be the fastest one but it is by far the most reliable of the performance Merc outboards that I have owned! Great motors just poor on mileage. On a side not Wicky I will take those injection parts. I will cover all frt just hit me up.
There is some good info in the thread, I think the first thing you should do it you buy it is remove the oil injector as that seems to be a source of concern. Nothing wrong with doing a little bit of mix.
If the boat is in good shape, and the motor checks out and you like it roll with it. Everyone is just giving you advice.
When I bought this boat I was told all sorts of things, and if it didn't suck water grass in the lower I wouldn't have done everything I did to it. It's just the chance we take when we buy something we want and like. I've seen these O/B run for a very long long time, and some here have had that happen. There are others that experienced something different, and I sure there are variables to consider in those opinions.
But looks like a clean boat!
When you want to sell the 22 with twins give me a call 6613730791 - Walt
So I'm going to see if I can rent a compression test kit and take it down with me to check the motor as well
