I'm getting my HP 500 rebuilt and am going with aluminum Brodix heads. Is there some kind of coating I need to get for these? I've read about "marinizing" aluminum heads to help with corrosion. I only boat in fresh water if that matters.
Dart does a hard anodize coating in the water jackets on the marine heads. Find a quality anodizer and see if they can do it. Maybe try talking to Brodix and see if they offer it. We are a Brodix distributor, but I've never seen that as an option
Actually it does help. We see a lot less corrosion at the areas Barry just described (mating areas at gaskets)In my opinion, and I do a lot of anodizing......is isn't going to do a motherfuckin thing. Anodizing cast materials is a crapshoot anyway, too many nooks and crannies. Especially when other machine operations...its a waste of money. All it will take is one scratch, one fucktard to stick something sharp in the water jacket, and all that prep goes to waste. Then they are subjected to heat.
Dissimilar metals will be enough of an issue with a marine engine.
Just what you deal with to have a water hotrod.
Brian
