37 boat
- Aug 27, 2008
- 640
- 518
Does anyone on here have the capability to machine a 3/4 16 O-ring boss thread in some blank fuel rail extrusions?
It's basically a standard thread with a relief cut in to seal an o-ring. Used widely in AN fittings.What is a 3/16 o ring boss thread?
Here is a fuel filter with a o-ring boss threadWhat is a 3/16 o ring boss thread?
It needs to be pretty precise to get the right amount of "crush" in the o-ring. Needs to hold 60ish pounds of pressure for EFI.Seems quite simple, threadmill it in and undercut? I have parts that need random machining like this too but haven't gotten around to it
Yeah, I'm not sure if it could be chucked up in a 3 jaw chuck? Wanna try?Still easy to machine if you know the sizes..
Kinda awkward holding it though.
Yes, I'm in Havasu. I can bring the fuel filter pictured above to measure dimensions. The thread itself is 3/4 16, the fuel rail I.D. is already sized for 3/4 16 at .6875Id clamp it to the table vertically on a knee mill and then offset the head to reach it if it was me..
Might be able to grab it in a chuck though. Wouldn’t know unless I tried.
you in Havasu?
Since I'm doing a lot of this stuff myself I was tempted to tap it NPT but I agree its not the correct way.Yes, i do them on the lathe sometimes. For some fuel rails i have a collet i made that holds them concentric. You can indicate and 4 jaw it also.
This is why hack shops run NPT pipe threads in rails. It's completely incorrect to do so, but they are usually too lazy, or lack the skills and capabilities to do an ORB port properly.
this oil pump i have has the oring business. i was expecting to just have a npt fitting in there but had to rebuy oring an fitting ones. i guess "flamable fluids" use orings as npt allows those fluids to naturally wick up the threads under pressure? not to mention npt will eventually stretch the material if dug in too much?
When you refer to the cross section of the port are you referring to the depth of the relief for the o-ring? My crude measuring tools give me a cross section of .084 on the o-ring and I show approx. .100 on the depth of the relief on the fuel filter.RD should be able to do this with a 4 jaw chuck on the lathe and a small boring bar or other high relief cutter.
You just need to make sure that your port has a greater volume cross section than the cross section of the o-ring (otherwise it will essentially hydraulic when you try to squeeze it and there is nowhere to go). And i usually shoot for 15-20% cord compression in one dimension, while accounting for that squeeze out in the other.
An o-ring with a cord thickness of 0.087" (a #908 o-ring for -8 which is probably what this is) should have a squeeze in one dimension of between 13 and 17 thou.
IMO it is probably better to squeeze the o-ring in the concentric dimension than the axial dimension. This helps to keep the fitting from working itself loose. In this case i would probably shoot for closer to 10% squeeze as you need to give a slight chamfer to the entrance in this case. I use 15-20% when calculating for an axial squeeze.
Yes, there is a tool available to machine it in one step but it's pricey and I don't have a mill or a lathe and I sure wouldn't want to attempt it in a drill press.looks like what you want is an MS33649-8 port. That's the spec for a port to accept an AN fitting with a 3/4-16
Hey @lbhsbz, what happened to your post about using a crush washer? Not a good idea? I had not seen that in a EFI application before but they are used in brake systems that have way more pressure. Discuss...
I edited it into my first post (at the end). Plenty of EFI systems use crush washers....Like almost everything Toyota made up till about at least 2003 (haven't worked on much past that)....even though toyota typically runs about 45psi I thing (never checked toyota fuel pressure...the pumps don't suck like GM ones). It's just a gasket. I'd not hesitate to even use a firm fiber washer in a pinch, although the material will need to be suitable for gasoline, which is likely why it's easier to just pick copper or aluminum for the crush washer/gasket material. While brake systems typically run under 1300psi on the street, it's not uncommon to see over 3000psi.,,,And copper washers work fine if all sealing surfaces are parallel and in good condition.
Thanks for the reply, this would definitely be the easiest solution. I have a 3/4 16 tap...the only concern I would have is making sure I tapped the hole dead straight.
Thanks, I'm in Havasu but I get to O.C. fairly often. I'm sure I can "McGyver" some type of guide/jig, I just need to put some thought into it.It's not hard...use a guide. Dunno where you're located...but if near Long Beach, bring it by and we can make it dead straight. If not local, I'll PM you my number...give me a call and we can talk about what junk you have laying around and find a way to make a "straigtness" jig.
C
Crush washers are only good if the fitting was designed for them, don't use one on an ORB fitting.
A crush washer is a gasket suitable for use between any 2 flat and parallel surfaces...what do you know that I don’t (with respect to crush washers)?
I'd offer @RiverDave to, (you)buy the tool, a couple cases of beer and he gets to keep the tool!! Next time(at shop rate) you or a buddy needs it done, you know where to go.. jmo
I turn them with a boring tool on lathes but on a mill a porting tool makes life easy. Look up SAE J1926 for correct dimensions.I would just do it with a boring bar and the compound on a lathe. Don’t need the tool
Thanks Dave, I will hit you up next week. I think I might join you guys on the ride tomorrow night as well.Bring it all over after the weekend and I’ll take a look at it. I can tell you in a few minutes if it’s going to be quick and easy or not
