LSX 416ci 650HP complete engine NEW LS2 block Trickflow LS3 CNC heads Manley rotating
Hardcore1
New LSX 416ci PUMP GAS complete dynod engine, this is a high end build with the best parts available@the price! Engine is suited to a Pro Street/Strip, Drag Race, Sand Rail or Drift application, the engine was dynod with a single plain intake and Holley 750cfm Ultra Carb@615hp@6800rpm, engine comes with a fabricated Hi Rise intake wich from our R&D on the dyno adds 30-40hp over a carb! So were guesstimating it@650hp with the Hi Rise.
NOTE! This engine is built strong enough for NOS or boost so easy to bump this to 1000-1300
HP (will need to run E85 or race gas)
Specs
Block New LS2 with ARP main studs and ARP head studs
Manley 4.100 forged 4340 crank
Manley 6.125 forged H beam rods with ARP2000 boltS
Racetec Custom forged 4032 Pistons 10.8:1cr
Total Seal Plasma Moly rings
Trickflow 255cc CNC ported heads
Hinson C7R timing set
Melling oil pump
TSP fabricated Alum oil pan kit 6.5qt(we can change for the cast retro rod pan with spin on filter if application is to go in a early muscle car)
LS3 rockers with bronze bush trunion upgrade
Moly BTR pushrods
Comp custom cam and lifter kit
TSP faricated Hi Rise intake with 102 throttle body and fuel rails
Trickflow 65lb injectors
$10,950
We can add Holley ECU and loom if needed $1000
Engine was dyno'd with a Edelbrock dual plane intake and Quick Fuel 750 carb it made 615hp@6800 and 535lb/ft@5200, we can arrange a chassis dyno to tune you ECM or we can supply a Holley Terminator X kit with correct injectors for intended application pump gas, E85 or race gas!
