MPHSystems
Hallett 240
- Sep 10, 2021
- 4,008
- 9,922
The connector on the release cable to my trifold bed cover snapped sunday and I had to crawl up the bed to release it. I decided the best way to fix it required a tap and die and a screw. Well I spent more time looking for a 8-32 tap, die to clean the cut screw and #19 drill bit than it took me to perform the repair. II want an all-in-1 tap and die and drill set. I did look at this one, I’d like to know if anyone has used this set or could recommend a set. I only use taps/dies a few times a year so I think homeowner quality is fine for my needs. This one has SAE and metric taps and dies and the correct drill bits
I’ve actually spent significantly more than that on just 1 Starrett tap handle as a gift for a friend. For me, this is the budget range I’m looking to spend for a set.
