Pesky Varmint
- May 12, 2013
- 276
- 390
I'm surprised that no one has gone back to an old school conventional speedometer. It will add at least 5 mph to your boat!
Most people are aware of the issue with a bunch of Livorsi GPS speedomters - The original design used an antenna that is battery powered, and eventually the battery will go dead. Some people have been able to change the battery inside the antenna and their speedo will keep working, but a lot of people have tried this and it doesn't work because the GPS receiver will lose it's programming eventually when the battery is dead.
Livorsi offers a battery-free replacement antenna for about $200, but on their website they state that the speedometers with the molex type 3 pin antenna connector aren't compatible with the new antenna and can't be repaired. My speedometer is one with the 3 pin molex connector, so for a few years I have just gone without a working speedometer because I didn't want to spend the money for a completely new monster GPS speedo.
I started doing some research into this, and found out that what Livorsi says is complete BS. The speedos use a standard GPS signal, called NMEA0183. This means that any GPS antenna that is compatible with NMEA0183 can be used. Also, the 3 pins on the molex connector on the gauge are for 12V, ground, and the GPS signal.
I found a 12V replacement GPS receiver on Amazon.com for $99, which looks to be the exact same unit that Livorsi is selling for $200.
Here is the GPS receiver that I bought:http://www.amazon.com/Sierra-Intern...&redirect=true&ref_=oh_aui_detailpage_o05_s00
Some people have used a Garmin GPS receiver which works fine also, but the Garmin units run off of 5V, so you need to also wire in an adapeter to convert 12V to 5V. I chose the Sierra receiver because it is a direct 12V connection for a clean install.
Yesterday, I pulled my boat out of the garage and wired in the new antenna. It worked great and was an easy fix. The new antenna has 4 wires on it, red, black, white, and green. The green wire isn't used for the speedometer, so just connect the red to 12V, black to ground, and white to the GPS signal connection on the speedometer. If you have the 3 pin molex connetor like I do, I think this actually makes for a better install. Just match the three wire colors (red, black, and white) from the new GPS receiver to the same color wires from the 3 pin molex connector. I soldered and heat shrink wrapped the connections from my new antenna to the molex harness for the gauge. See below for pictures.
View attachment 484878 View attachment 484879 View attachment 484880 View attachment 484881 View attachment 484882 View attachment 484883 View attachment 484884
Awesome! I'm glad it worked out for you!,Hey @steamin rice I just wanted to say thanks. I know it's an old thread but I just got around to performing this fix and it made my speedometer great again.
Yeah, mine quit working altogether, when I turned the key on it would sweep then settle on 10 mph and stay there.So was the issue that the speedo wouldn’t work at all? Problem with mine is it will work for a bit then jump all over the place like crazy then work then sometimes go to zero.....not sure wtf it is
When I turn the key on, the needle just moves up to about 3 mph and then back to zero. I believe that before it would go to 100 (3 oclock position) and then back to zero.
Yes it should do the full sweep of the needle (self test) every time power is applied. That doesn't sound like an antenna problem so make sure the +12 and ground are solid. I don't fix the speedos, just the old style round antennas. The speedo is hard to get apart because the bezel is rolled on. I did fix one but it was a big PITA. Not sure where you are at but I would be happy to connect it up to a known good antenna/power connector to test it for you.
For sure this is a good way to go but just wanted to mention that I still fix the original pucks if somebody wants to keep using the round one. $75 includes FedEx return ship.
I was thinking the same thing, I have the same problemWhat do I need to send you? Just the puck?
Sorry for the delay guys, I just saw the posts.I was thinking the same thing, I have the same problem
Yes all I need is the puck. I have a test speedo and harness that I put in my Jeep and drive around to test with.
Ok.
Good thing I'm not using it in my jet bote because I doubt your Jeep does 100 mph.
As stated above
So I am currently doing this modification currently to my livorsi speedometer. Can anyone tell me which wires go to which wire on the gps antenna? I looked at the instructions and they offered nothing. The antenna has red, white, black, and green. From the speedometer, which colors do I connect the red, orange, black wires to on the 4 on the antenna? Thanks
post #1 looks pretty clear
"The new antenna has 4 wires on it, red, black, white, and green. The green wire isn't used for the speedometer, so just connect the red to 12V, black to ground, and white to the GPS signal connection on the speedometer."
