beerrun
- May 25, 2010
- 4,818
- 9,646
Idk how to link the video can someone help
Yes I agree but what kills me is the fire truck has to have an on board generator for when the battery gets too lowJust like electric buses and soon semis. They will become very common over the next decade. Completely ridiculous, but thank the voters.
Someone might want to let the chief know thatYes I agree but what kills me is the fire truck has to have an on board generator for when the battery gets too low
This is misleading the public. It is not all electric it’s a Hybrid. Just like all Hybrids they are not all electric!Yes I agree but what kills me is the fire truck has to have an on board generator for when the battery gets too low
Is a mute point.Can the truck operate while charging? Basically, is the genetic large enough to produce enough electricity to operate the entire rig at max demand? Cause if it can't do that, what the hell is the point of it at all?
Point is…Virtue signaling.Can the truck operate while charging? Basically, is the genetic large enough to produce enough electricity to operate the entire rig at max demand? Cause if it can't do that, what the hell is the point of it at all?
Haha!! Good point!Is a mute point.
Volvo Penta batteries and a BMW Diesel engine.
It’ll be in the shop more than it’s out doing its job.
Oh absolutely! I'm just trying to gage this trucks probable effects on public safety.Point is…Virtue signaling.
That’s going to be the solution for your HD trucks (Ram/Chevy/Ford). They will be diesel electric to charge or probably while towing but otherwise run electric for as long as they can (ie not towing or just around town).Sounds like a similar operation to a diesel-electric locomotive.
this is day 5 of it being in serviceJust ridiculous! Not sure if that rig is even in-service yet. During its debut back in May, the water tank ruptured.
The EPA and CARB have been ruining rigs in the fire service for years now. The fire truck I work on has had many smog related issues. Mainly Regen issues. It’s only a matter of time before SDFD gets one of these stupid rigs
or we can put charging stations at every fireYes I agree but what kills me is the fire truck has to have an on board generator for when the battery gets too low
They will still carry batteries unlike DE Locomotives so they can be considered hybrids and get the EV rebates.
I would think if you put electric motors on an HD truck at each wheel and then energized them with a diesel generator your towing capacity of the vehicle would either double or be restricted by the weight carrying capacity of the axles and hitch and tires that they could install on a regular light duty truck without turning it into a semi. And it would be more efficient and better performing than running on the diesel direct connected to the drive train. Removes the need for a transmission, all the diffs and all the axles and driveshafts making the truck more reliable as well.I’ll take the opposing POV…I think it’s waaaay more efficient to have the diesel motor to mechanically move the vehicle. Too much conversion loss otherwise.
So I don’t think we will see series hybrids (like a locomotive) in over-the-road vehicles.
I guess we will have to wait and see
We can just add a charging station next to every fire hydrant….or we can put charging stations at every fire
Catch the hydrant and charger.or we can put charging stations at every fire
Each traction motor has a differential in it. Tractive effort is like 30,000 lbf.I would think if you put electric motors on an HD truck at each wheel and then energized them with a diesel generator your towing capacity of the vehicle would either double or be restricted by the weight carrying capacity of the axles and hitch and tires that they could install on a regular light duty truck without turning it into a semi. And it would be more efficient and better performing than running on the diesel direct connected to the drive train. Removes the need for a transmission, all the diffs and all the axles and driveshafts making the truck more reliable as well.
Those DE locomotives have some serious tractive force and their biggest problem is getting the friction on the track to apply it. Now they inject sand on the rail to increase the friction under the wheel to reduce slippage.
We will see!
I brought it up a couple of weeks ago when someone posted the above dispatcher memewas wondering when this was gonna come up on here
It's one motor per axle right?Each traction motor has a differential in it. Tractive effort is like 30,000 lbf.
From what I'm hearing the new Dodge Ram Electric Truck will utilize this same backup generator method. Really think all electric vehicles should be setup this way until battery life can be extended way beyond current mileage, and the electric grid infrastructure is robust enough to charge 200 Million Vehicles. Neither are close to being ready to go full blown EV!New electric fire truck when the batteries get to 20% you guessed it an on board diesel generator kicks in to recharge the battery. Can't make this shit up but we have to go to all electric
Thanks for your supportGlad our firefighters are going to breathe clean air on the way to fires Pure genius.
Gotta pass probation before you get the bucketLooks like this beauty failed the acceptance test / ruptured water tank….
Anytime. When i need help i want the fastest damn truck with the best person to do the job. Equity and clean energy can suck it. Dr. House showing up in this works.Thanks for your support
You're speaking of a diesel/electric locomotive, right?Engine makes 4000+ HP. Each axle has a traction motor. I want to say tractive effort to start movement can go up to 40,000-50,000 ftlb
YesYou're speaking of a diesel/electric locomotive, right?
Ever since the Volt came out with the Mostly series hybrid design, I have thought that was the best approach. A plug-in series hybrid, even better.From what I'm hearing the new Dodge Ram Electric Truck will utilize this same backup generator method. Really think all electric vehicles should be setup this way until battery life can be extended way beyond current mileage, and the electric grid infrastructure is robust enough to charge 200 Million Vehicles. Neither are close to being ready to go full blown EV!
We’ve had a Volt since 18, great car, kinda best of both worlds if you need carpool lane access, etc. must have been why GM discontinued it…….fucking idiotsEver since the Volt came out with the Mostly series hybrid design, I have thought that was the best approach. A plug-in series hybrid, even better.
