bk2drvr
- Jul 9, 2015
- 1,671
- 2,140
How many of you guys run them? I’ve got an 18’ Sierra with the 5.3. Should I get one?
I have one on my wife's Camaro and cant believe how much oil it collects.How many of you guys run them? I’ve got an 18’ Sierra with the 5.3. Should I get one?
I have one on my ecoboost, it’s amazing what it catches, fuel, oil and water. For direct port injection it’s a must as your valves will thank you! It fills up in about 3-5k miles View attachment 692191
What would a catch can be. Asking for a non mechanical friend lol !
They go back up to the pcv to ventWe run the Jaz set up with the little breather filter on our Spec racer Fords. Are you guys running one side vacuum and one side sucking in blow by? I don't see a vent on your examples?
Did you just go with the universal kit?
Two questions:
Are they CARB legal ?
Do they adversely affect your warranty ?
I run a Moroso can on the wife's 6.2. I think it was like $150.00. Does the job but doesn't look as fancy as the ones you guys have.
You wouldn’t believe what I catch in mine. With direct injection there is no gas to clean the back of the valve so that stuff coats and sticks to the back of the valve and stem.
Is it necessary for direct injection or port injection? They are 2 different locations for the injectors. I do not know of any manufacturers using both port and direct injection systems on the same engine.I have one on my ecoboost, it’s amazing what it catches, fuel, oil and water. For direct port injection it’s a must as your valves will thank you! It fills up in about 3-5k miles View attachment 692191
Lol I meant direct injection hahaIs it necessary for direct injection or port injection? They are 2 different locations for the injectors. I do not know of any manufacturers using both port and direct injection systems on the same engine.
Lexus and Toyota have run port and direct (google D-4S injection) together on many engines for over a decade [emoji106]
I know for sure Lexus no longer does DI-only on any engine.
Ford started offering it within the last few years also.
Great addition on my duramax for the last 250k miles. Saves the exhaust y bridge and turbo vanes nice and clean and not getting filled up with goo epoxy coat oil soot looking crap that turns rock hard.Are diesels good candidates for catch cans?
Since 100,000 (I've got 212,000 on my truck now), I disconnected the 3 electronic connections from the EGR, so hopefully that has helped some. Where does the PCV reroute drain to, a catch can?I used to run one on my LS engine in my GTO. Its amazing how much oil those things retain, that was destined to roll right into the intake tract. You'll likely fail the CA SMOG visual portion if the guy knows whats going on, but typically these things take 15-20 min to install so its not too bad to remove it every couple of years.
As far as diesels go, you are also right. I never did the PCV reroute on mine, I wish I did years ago when I blocked the EGR at 3,000 mi.
Mine's an 11 LML. Looks like I'll have to do some PCV reroute research.I'm sure it depends on the truck, mines an LBZ duramax. They plumb it out onto the ground, but you could certainly use a catch can to be more eco friendly =)
My 78 harley is the same way, crank case breather runs out a hose, and dumps under the bike.
got mine last week for my 6.2L i already did the valve cover swap and will be installing the can asapI run a Moroso can on the wife's 6.2. I think it was like $150.00. Does the job but doesn't look as fancy as the ones you guys have.
