yep thats me . i used the west marine polyester resin # 516237 for a gallon with the ever coat sea glass # 100917 2 inch and 4 inch .. starting with the 2 inch to join the edges then the 4 inch to add strength ..also a 36 grit sanding disc on my 4 /12 inch angle grinder for prep .. cant believe how strong it all is after you get a good coat all the way around .. mix small batches at first to get the mix right then go from there.. good luck :thumbsup looking back on it i got some mat that was 4 inches wide also and used that.. you can see the strips sitting there.. just start small and work your way out getting bigger with each pass..
thanks folks for the love it took alot of sanding and buffing to bring back the disco gold flake but i think it turned out pretty ok .it looks sharp for a 1976 i must say .plus she rides nice we love this boat .:
