Jacuzzi YJ Golden Eagle to Berkeley swap
jetboatperformance
The Jacuzzi YJ Golden Eagle is similar in design and installation method to what is termed an insert jet such as a Berkley 12 JE or Dominator 12TD (in terms of positioning and mounting ) this style of Jet were "set back" by design and they permitted or allowed the engines to be set back in the hulls as well. This type "jet set back" made for more cockpit room (one advantage alone) and simplicity of production installation , however most insert jets like these did not offer quite the performance as their standard position brothers like the Aggressor 13000, Berkeley 12 series Or Dominator 12s jets . The Jacuzzi Golden Eagle like its brother the Jacuzzi YJ is an Axial flow jet vs the Berkeley12je and Dominator12td which were both Mixed flow jets. Axial flow Jets have their place in life and can provide bigger heavier boats such as day cruisers with low speed lift and strong pulling however Axials don't seem to respond in the higher rpm and increased power ranges as well as the mixed flows to the HP and performance demands most folks nowdays want or desire . This Thread is to show our "Swap out" of a Jacuzzi YJ Golden Eagle for an intentionally set back Berkeley 12J custom built jet , The swap will include a custom machined Berkeley intake set up for a ride plate and shoe and a Blueprinted jet built by my son Josh to match the 600 + Hp Big Block Ford the owner installed last year ..
First out comes the Jacuzzi ... then the Sawzall ...
jetboatperformance
This is Josh's latest creation been months in the making ,this swap was particularly challenging due to the design of the Jacuzzi mold insert we removed the Jacuzzi Golden Eagle and built/ replaced it with this Hibred Berkeley jet , The Berkeley contour intake was specially modified with custom designed billet "wings" to fill the large void left by the removal of the Golden Eagle glass mold insert and avoid glass work The basic jet is a Berkely 12JCG has a reworked suction, features JBP 17-4 inducer shaft, Inducer Impeller , detailed Aggressor Mag Bronze Impeller, JBP sportsman bowl and loads of Joshs custom fabricated touches. including clean out reinforcement kit, custom cad designed fabricated pump braces and more.. The BBF motor dynos at 600hp + also received one of our new BBF rail mount kits The boat is a 19' Challenger Mini cruiser
before..
during fabrication
Today..
