Jack Plate Recommendations
MonkeyButt70
I want to install a Jack Plate on my 2021 Regency 250 DL3 with the 300 Verado. Which Jack Plate do you all recommend? The motor currently sits very low and rides wet. I want the ability to adjust as I want and not just using the bolt holes on the motor plate. I need to raise it at least 2.75" and with the just motor plate the most I will get is 1.5" right now.
mobldj
sell you mine cheap.used once
Bajastu
I have an un-used Bobs 6” manual plate. $500, you can upgrade to an electric or hydraulic power unit real cheap. Located in Canyon Lake, CA
Bajastu
I wouldn’t trust a CMC with a 300 Verado or any other outboard of value.
MonkeyButt70
I agree. I’m only looking at the Atlas or Bobs. I’m curious is the hydraulic worth the money over the manual lift.
Bajastu
The hydraulic is worth the money if you plan on adjusting on the fly all of the time. But if you want just a lift ,set it and forget it, run with a manual.
MonkeyButt70
Is there an advantage for adjustment on the fly?
Bajastu
Water pressure must be monitored with raising it too high, otherwise you will cook your engine. In your application with a pontoon, I’d set a height and leave it alone.
Use trim for low water maneuvering.
