FROGMAN524
- Mar 16, 2013
- 5,405
- 9,569
The separation/bulge or the low air pressure.
Is a $350 tire a gamble you are willing to take?
Weird looks like the sidewall tread is touching the ground.It’s got 65PSI in it. Door says 60 front 70 rear when cold.
what's the date on them?
Drive slow to the shop that sold you that tire. That tire does not fit YOUR way of going. Your boat trailer and vehicles always appear perfect. Get rid of that tire.
What do the tires and wheels say for max pressure? A quick way to get a tire to look like that is to over inflate it and drive on it. The manufacturer recommendations are for factory tires (or their equivalent) on factory wheels. Most wheels won't have a pressure restriction but low profile tires are rarely 70 PSI or above tires. I'm betting those tires say max of 60 PSI.
I always heard the dents are okay, the ones that stick out aren't.Truck suspension is stock factory
Wheels are stock factory
Tires are stock factory (2nd set)
Tires are rated for 80PSI
Um yeah wtf!34th week of 2020. They’ve got 2,800 miles on them.
Looks like belt separation from improper rotation of radial tires,
or running tires low on air pressure, an over torquing the sidewall.
What are the two weird lines running around the sidewall?Read above. 2,800 miles, stock inflation per door and not overloaded. It’s a highway cruiser. That’s it.
