Holley 950HP carburetor - Fresh
Bigbore500r
Holley 950HP carburetor, ran on dyno then drained and flushed / cleaned.
Will come with fresh needle valves, new Holley "blue" non stick gaskets, and fresh 6.5 Power valve. Included jetting is 78 / 86, with rear PV blocked.
These carbs have 1 3/8" venturi with 1 3/4" Throttle blades (undrilled from factory). They flow closer to 830cfm, when measured at the standard 1.5" of vaccuum.
This carb does not have a list # stamped on the main body, but it is all holley components and measures as listed above. Similar to current list # 80496-2
Metering blocks are original style 3-hole emulsion holley blocks. Carb has replacable high / low speed air bleeds and 4 corner idle ciruits.
Asking $550 shipped. Will come with a Trump 2024 sticker, because RD SUX
37 boat
Holley 950HP carburetor, only ran on dyno then drained and flushed / cleaned.
My motor is happier with a 4500 dominator, so selling this 4150.
Will come with fresh Holley .120 Needles (factory spec), new Holley "blue" non stick gaskets, and fresh 6.5 Power valve (also factory spec. Included jetting is 78 / 86, with rear PV blocked. Factory jetting was 79 / 79 with a 6.5 PV in the secondaries. All other aspects of carburetor are stock, including air bleeds, metering blocks, idle circuit and emulsion tubes.
Holley updated list# for this carb is 80496-2
Message sent
C-Lo
You in Havasu? If so I'll grab it next week when I'm up there if you still have it
Bigbore500r
No, in Thousand Oaks. I can cover shipping if you want. Please check updated ad, theres a few changes to the listing and actual photos of carb.
I noticed that the listing number isn't stamped on the main body, so want to be transparent about that. It's a 950 for sure, based on venturi dimensions and throttle blade / base plate size.
Thanks
