Hi Torque IMI starter
brendellajet
Starter is on a big block chevy. Looking for a wiring diagram. Boat is wired for stock mercruiser starter. The hi torque starter is missing several terminals and I'm not sure how to modify/fix.
Wondering if I should replace it?
brendellajet
Just in case anyone finds this post later on, you can in fact run a hi torque mini starter in an otherwise mercruiser setup without an external starter solenoid.
lenmann
How?
brendellajet
In my application(replacing 502 Mag MPI from mid 90's...
Yellow wire with red stripe is the intermittent 12v. Wire directly to the spade connector on the starter.
Everything else goes to the post on the starter.
lenmann
Thanks man. Easy peasy.
