eand28
- Jan 6, 2018
- 571
- 1,013
Got a question for the offroad suspension gurus.
I have some tapered studs to go from a typical tie-rod to a heim joint.
The tapered stud is two pieces and the 12 pt bolt is what holds the two pieces together sandwiching the ball of the heim joint.
For safety purposes I know I need to run a safety washer on the bottom side with the bolt but I'm not sure the best way to do it.
One option I thought of was machining a custom washer like this with the I.D. to match the bolt diameter.
The other idea I had was have a spacer like this machined so that it is one piece sort of like this.
Any advice is greatly appreciated and any machine shop recommendations are also appreciated. I'm leaning towards the one piece route to replace the existing washer (circled).
The ID of the heim joint is 3/4 and the bolt is 3/8.
