Hallett 400 (customer build)
Nordic Boats
We are building the 2nd Hallett 400 with twin 600s, This will be an awesome build stay tuned.
ToMorrow44
27 Advantage TCM 800efi
#6s and 600s ought to be a bulletproof package!! Nice boat, rigging looks great!
Nordic Boats
The 600 SCI's are here for the 400, we pre rigged them for the stage 3 Whipple kit. After the warranty on the engines are up customer is going to bring it back and upgrade them.
wsuwrhr
The Masheenest
Subscribed. :)
I love me some twins.
Are the engines staggered? The drives look pretty close.
Brian
NOTSOFAST
Pretty sure that is a standard side by side set up. If it were going to be staggered, one pair of the stringers for the engine mounts would have to extend into the area that the fuel tank is currently in. Also, the rear bulkhead in that configuration would be in the way.
NOTSOFAST
What's up with green tape on the side of the boat?
NOTSOFAST
I recall seeing pricing on the bigger Halletts before it all went away and I thought the 40 was based with 520's and Bravos and it was around 375k with that package. If this boat really has 6's on it, I'd say north of 400k for sure.
NOTSOFAST
Yes the hull is from 2016 but it’s the new bottom so I agree it would be considered a few years old and therefore a litttle less valuable if the bottom were the same old thing. I’d think you’d get a little value back because of the updated bottom and the fact there’s only two of them so far.
Gelcoater
I think there’s three?
NOTSOFAST
I only knew of this one which was number 1 and it sat in the corner of the big shop and the 1100 boat which was number two and built basically at the new little shop before Nordic took it. But, you would know better than anyone so who’s got the third one?
There’s the 2 on the website. New tops not sure of bottom
Runs2rch
The Gen2 40 original bottom worked well. I think Jerry saw how well the 29 worked with the Peter's design he adapted it to the 40. Nordic had to do quite a bit of work to make it work right.
I'm guessing they fixed this one as well???
LakeMead Boater
John's 40 is the original bottom right?
I think it is. I can’t remember off the top of my head.
And yes, I believe Thane said at the boat show in 2018 that they were fixing this one. This was right after they did everything with the open bow 400 with the 1100’s
HCP3
What is the cabin height inside this big-dog?
LakeMead Boater
Weight isn’t much more than a lot of heavily laid up 34’ or 35’ boats.
It’s still heavy but I don’t think it’s quite in the need of a goose neck.
Runs2rch
Hallett has it at 14k. That has to be on the trailer.
NOTSOFAST
If the owner of the boat was going to tow that boat back and forth across the country for poker runs and boating at other lakes or Florida, it probably wouldn't be a bad idea to goose neck the trailer. Definitely easier on the tow rig and the driver even at 14K. It would be a beast for local boating otherwise.
I'm no engineer, but that seems like a lot of stress on the four bolts holding the hitch coupler to the frame of the trailer. o_O
Hammer
That has to be temporary to move the trailer around. The guys at Adreneline build some of the nicest trailers in the industry.
HydroSkreamin
StressEliminator
Actually it’s pretty commonplace on large boat and equipment trailers.
This is a 47 Fountain with QC4’s, and I’m pretty sure the boat itself weighed in around 12,000 lbs.
I’ll take 4 bolts in the trailer compared to 2 bolts in the truck hitch...
FROGMAN524
Same 4 bolt setup on this MTI of SBRs
