D19
- Aug 13, 2018
- 2,495
- 4,944
Has anyone here ever had one of these engines fail?
How many miles? Did they replace it or or build it both times? What year truck?There’s a few threads already on this topic.
I had my 6.2 lock up twice due to lifter failure. Luckily under warranty.
Did you have any type of cylinder-shutoff disabler installed?Has anyone here ever had one of these engines fail?
What year was your truck?
Disabling the afm doesn't fix the issue. Gm lifters sux, especially covid Era built vehicles.Ya disabled AFM at 40k (Superchips tuner). Locked up at 83k miles. Out of warranty. Looks like I'll be putting a new factory crate in it, I just don't want it to happen again, wondering if I should look into the aftermarket.
Sir - I must disagree....Disabling the afm doesn't fix the issue. Gm lifters sux, especially covid Era built vehicles.
Gotta swap the whole motor to non AFM cam and lifters. And use Johnson lifters.
2017
Accelerating from the stop light, loss in power, felt like I was pulling a heavy trailer, grinding sound, thought it was torque converter letting go, let off the throttle and it locked up.
Was talking my neighbor about this I told him they have the plug in deals he said they don’t do shit need to swap lifters and cam. The lifters fail regardless of ecu mods he said. He was in market for new truck and this scared him and he was a former mechanicDisabling the afm doesn't fix the issue. Gm lifters sux, especially covid Era built vehicles.
Did it seize up? If so, it doesn't sound like an AFM lifter failure, sounds like something in the rotating assembly let go, or it possibly dropped a valve.
There does seem to be quite a few instances of L86 6.2 "lock ups", my friend's 2022 trail boss silverado shit the bed at 2,000 miles, randomly while cruising on the freeway. Entire motor trashed. Dealer hasn't told him yet what the failure cause was.
$10,500 at the dealer for a new engine
aftermarket you could do it between 6-7 Per my buddy who just went with the dealer package for the warranty
yes,Installed at that price?
yes,
oops, his was a 5.3
i turned my afm off 60000 and just turned 305000 and doing great. I also run mobil one since new and change every 5000 The lifters fail when they go from v8 to v4 modeWas talking my neighbor about this I told him they have the plug in deals he said they don’t do shit need to swap lifters and cam. The lifters fail regardless of ecu mods he said. He was in market for new truck and this scared him and he was a former mechanic
You’ve gotta be kidding me…..you wanna go down the ford road? Maybe search the lounge a bit and read up on eco posts for a bitGM is stupid. This is basic shit that that hasn't been new since the '60s, and they can't get it right. I remember the steering shaft slip yoke campaign in about 2000....how many fucking years have they been making slipyokes? Now they can't keep lifters together?
New cars are trash. Toyota has had cams banging on solid lifters for 30 years and they work fine, and don't even need adjusting for 300K miles. Why is this basic shit such a problem for GM (and Chrysler)?
Did you just do the computer delete?i turned my afm off 60000 and just turned 305000 and doing great. I also run mobil one since new and change every 5000 The lifters fail when they go from v8 to v4 mode
I failed to mention Ford because I figured it was simply assumed that they were pieces of shit.You’ve gotta be kidding me…..you wanna go down the ford road? Maybe search the lounge a bit and read up on eco posts for a bit
I did get to work on a severely neglected Toyota with multiple issues this week, not sure how much longer it will be running, but it's still running nonetheless.GM is stupid. This is basic shit that that hasn't been new since the '60s, and they can't get it right. I remember the steering shaft slip yoke campaign in about 2000....how many fucking years have they been making slipyokes? Now they can't keep lifters together?
If disabled at low mileage, It generally helps with keeping the problem at bay, as it's not activating the AFM and collapsing / re-engaging the lifters constantly, which is what wears them out and eventually causes them to fail. Lots of AFM disabled trucks on the road past 150k.
Disabeling AFM also helps save the 6L80 torque converter, as the computer commands it to "slip" every time the AFM engages / disengages, and also commands it to slip slightly when locked up the entire time the truck is in AFM to minimize harmonics while running in constant 4cyl mode. That is the #1 cause of 6L80 converter failure - premature wear of the lockup clutch, which ends up eating the converter and sending metal thru the trans - initiating the death cycle.
If the AFM stays on, and the converter fails - Then you have to go see this guy.....
Guy in the area has ls software and turned it off.He tuned 27 more horsepower also.Did you just do the computer delete?
Change the oil every 5000 milesYeah… you fuckers are scaring… Running 2021 5.3 Chevy Silverado… with 28,000 flawless miles…
About to buy a Pulsar tuner, that disables all that AFM, DFM Crap…
If the motor fails.. then yeah…
Its getting pumped the fuck up.. .6.2L with mad fucking mods… thinking in the 550-750hp range… But it will run on pump gas… and hopefully get ok fuel economy.. Why cause its my Daily…
I live in a County in NV, that has no smog, and I can do what ever the fuck I want….
Best post I have seen yet!I failed to mention Ford because I figured it was simply assumed that they were pieces of shit.
Instead they chose to fuck the American people by duping them into buying 6.0 and 6.4s….which cost a lot of them more than GM and mopar’s bailout.And yet...
Unlike GM and Dodge...
They haven't filed for BK and had to have the guberment step in and bail them out.
This is a good way to go: https://www.jasperengines.com/blog/jasper-remanufactured-gm-afm-delete-engine
Three year, 100k warranty, includes a tuner to program the nonsense out of your ecm.
Random Lifter/pushrod failures and related issues are common on these engines , We look at them almost weekly for my mechanical damage inspection business I believe the lifters themselves are at the heart of it , Often these motors are clean and well maintained , no overheat or lack of lube situations . misfire codes, "jiggle" and "ticking" seem to precursor
Ask Pat Purcell. He was selling ford's then and still is. He swore the 6.0 was the next best thing. And not to buy a 7.3 but wait for the new 6.0 to come in. Could of had a 03 7.3 still. Would be worth what it was new. Then the owner of South Bay Ford Gary told my buddy who was his friend. The 07 6.0 have all the bugs worked out. Bought a 07 and it was a bigger pile of shit. Ford could give 2 fucks about there customers.Highly doubtful.
But if you have the facts to back that up?
Damn 10k is alot for a stock rebuildhad a lifter go out on one of my work trucks last month, 2015 6.0 with 95k. Had our mechanic pull the motor and sent to JMS to be rebuilt. close to 10k to get back into service. This is the first failure we have had with the 6.0 out of 6 - 6.0L trucks with over 100k. Engine never seized just had a scraping sound, sounded like a pulley issue.
Rebuild was a little over 4k including cam lifters, rest is in the R&R including new mounts, hoses, water pump and bunch other stuff while the engine is out. thats 2k less than dealer and mechanic quotes with factory remanufactured or one of the jasper engines. GM and Jasper we’re over 6k retail for rebuilt unknown history engine.Damn 10k is alot for a stock rebuild
IIRC, the 6.0 doesn't have the AFM/DOD, so it has all "normal" lifters, not 1/2 of them hokey lifters like the 5.3 & 6.2 engines. But I guess in occasion they apparently still failhad a lifter go out on one of my work trucks last month, 2015 6.0 with 95k. Had our mechanic pull the motor and sent to JMS to be rebuilt. close to 10k to get back into service. This is the first failure we have had with the 6.0 out of 6 - 6.0L trucks with over 100k. Engine never seized just had a scraping sound, sounded like a pulley issue.
I wonder why not ? It would be the same rebuild, but with a late model 6.6 Cam, a normal set of lifters with the appropriate "buckets" that hold them straight. No other differences. Could it be they don't have the tuner device available ? If so, they could still build you an engine, and you could have a local tuner modify your ECM, or, send the ECM to Texas Speed, and they'll modify it for $400.00 IIRC.I called over there. They’re not in production
