Gentry twin turbo kit
Bb588
Hello everyone I am new here not sure if this is the right place to post parts for sale.
All the parts in the turbo kit are new and unused all aluminum parts are hard anodized for corrosion resistance. Ready for paint or powdercoat . All nuts, bolts, washers fittings, hoses, hose clams are included. Copper/Nickle intercooler with 3-stage sea pump, billet crank, JE pistons, Heads and more see list. This kit will make 750 hp on pump gas when put on stock 454. With good heads and 500 ci will be around 900 on pump gas more on race gas. Other parts included are listed below. Crank and sea pump are used and in excellent condition see pics and list. Please let me if you have any questions. 7500$
PARTS LIST
Turbo kit to many parts to list see pics
2 garret turbos with water cooled exhaust housings
Billet Kryptonite crank 3.92 stroke standard rods and mains knife edged (used)
New set of JE dished pistons extra HD Precision components pins not the stock je ones
Stefs Aluminum oil pan Anodized and polished. Never run was used on a show motor
New Crower Solid roller lifters with axle/roller pressure fed oiling
New Crower rev kit
New Pro Topline cast iron heads 320cc intake ports raised exhaust ports. Same as RHS heads before they were made in china these are the original ones from New Zealand good stuff . Heads have some surface rust from sitting see pics.
3 stage KE sea pump Needs impellers no corrosion (used) Pulley not included
Imco valve covers (used)
Mercury Dual cooler belhousing no corrosion has small crack at dowel pin hole definitely reparable see pics.
I have more pics just ask if you need to see others.
bonesfab
Do you have any numbers on the turbos? Any better pics of the inner cooler setup?
Bb588
Here are some pics of the intercooler and housing it goes in.
Bb588
Sorry for duplicate pics. I’m not very good with a pc
wzuber
Original post is 1/2020, over a yr. Old. Maybe be gone by now. Good luck. Looks like it had some nice parts.
