JBrock
- Mar 2, 2011
- 15
- 3
Completely one-off BRP edition American Offshore 2600
2 plus year renovation, performed by Boat Repairs Plus and Marine Customs of Denver NC (Lake Norman), just finished in mid-June 2017. Everything on this boat is either new or refurbished with less than a summers usage. Total hours since renovation is 22. (hour meter now reads close to 40 due to leaving the key on overnight).
Boat was totally stripped of all rigging and hardware, original rigging holes and cracks in gelcoat filled before the entire hull was primed where it then went through several block sanding stages in order to get the hull straight as possible. 6 color ppg paint job was then applied, followed by 3 initial coats of clear. The boat was then wet sanded and recleared with 2 more coats before final color sand and polish was done. Bilge was also recoated bright white.
Interior was completely redesigned from factory, new frames, foam and vinyl. Head rests are custom embroidered with new AO logo. Custom acrylic panels were cnc cut to enclose 4 new wetsounds 650xs speakers. Sub box for wet sounds 10" sub and custom amp enclosure for wetsounds SYN-DX 4 Channel amp mounted under dash. New LED lighting installed for courtesy lights, accent lights and cupholders throughout cockpit. Additional panels were cnc'd and laser etched for billet push button panels and speaker head unit. Entire floor is covered in cnc routed seadek that was custom designed for this boat. Hatch was reworked for supercharger and converted into a "roadster" rear seat configuration new electric hatch rams and relay.
All new wiring for entire boat with race terminations for every connection. Water resistant fuse and relay box wired for easy access under dash. New stainless and billet hardware throughout, to include: custom machined access and vent plates, cleats and fender pins, gas fill and vent with surge tank, bow and stern lights, grab handles, glove box and rub rail. Also includes new autometer gauges and bezels with GPS Speedo and recall. New helm, steering wheel, orbital pump and hydraulic hoses.
Fresh rebuilt dart 540 just installed mid way through June 2018. Currently setup on mild tune, underdriven with 5lbs of boost, setup for 89 octane. Engine just returned from dyno and currently has 1 hour of run time in boat. Full build and dyno sheets available. Engine components include:
Dart block with splayed mains
Callies crank
Oliver rods with new Oliver rod bolts
JE flat top pistons
Total seal rings
Isky billet Cam
Cloyes double roller timing chain and cover
High volume mellings pump
Large capacity oil and PS cooler with thermostat
Canton 12 qt pan
Afr 357 CNC heads with new seats, guides, retainers and valves. Ports have been reworked
T&D shaft rockers
Crane hydraulic roller lifters
Mooneyham 10-71 with two boost referenced 850 Holleys
Crane ignition box with msd distributor and taylor wires
Aeromotive fuel system
All hoses are AN
New accessories, billet pullies and brackets
New stainless marine gen III exhaust with custom dry to the tip 4.5" tails
Painted to match valve covers and flame arrestor
ITS box with bravo X upper and -2 sportmaster lower 1.34 ratio
I am sure I have left out a ton of additional work and rigging that has gone into this boat over the last few years. There were countless hours put into this build. This boat is practically brand new and it shows. I have a growing family and have moved to a sport center console. Trailer with new wheels and tires, new sunbrella cockpit cover, new docklines and fenders with covers included with sale.
$60,000. Price is negotiable, open to all offers.
PM, call or text
803.309.4271
Callies crank
JE flat top pistons
Total seal rings
Isky billet Cam
Canton 12 qt pan
T&D shaft rockers
All hoses are AN
PM, call or text
803.309.4271
