n2otoofast4u
- Apr 7, 2015
- 5,982
- 12,139
Ok, so I own this killer jet bote and its been damn flawless until it wasn't, but that's another story. I only had 1 issue with the boat and its fuel delivery.
After I make 4 or 5 good passes the level of fuel in the tank becomes low enough that when I lift hard the fuel sloshes to the front and starves the pump (High pressure EFI pump) and 60% of the time it wont re-prime. Typically not an issue, because I make 3-4 passes, go to the beach, flip a valve, transfer fuel to the other tank to fill it, and I'm off for another 4-5 passes. It NEVER runs out of fuel under load, because all the fuel is in the back. The issue as I see it is that the tanks are below the level of the pump, but I don't have a choice for that. The question is how to re-prime the existing pump when it runs out? Tap a fitting just before pump inlet and use a little auxiliary pump to flood it? I'm open to REASONABLE suggestions and have included a VERY well put together drawing of the conditions although its not 100% accurate, it represents the problem.
