Henchman1488
New Member
- Nov 8, 2020
- 3
- 1
Hello Forum,
my neighbor has a 15’ flat bottom hull he is giving away for free.
I’m intrigued and thought it might be a fun little project to tinker with.
I grew up at the river with jet boats and eventually built a twin turbo v drive Sanger mini cruiser.
I don’t ever recall seeing a flat bottom with an outboard, is this something fairly common and I’ve just never paid attention to?
I have always wanted an outboard and nearly purchased a super clea. Schiada with a mercury racing outboard but I started a new business and figured I would not have much time to use it. I liked the idea of an outboard because I would leave it alone as I have a tendency to go “overboard” with my projects.
As of now, I don’t have a boat at all.
I have a mercury 2 stroke, 4 cylinder 40 hp on an old POS bayliner bass boat that is junk with a really nice trailer I could convert for use with this little flatty.
my question are, would it be ideal to build a billet jack plate to mount the engine?
If so, how far back should I extend the engine and what distance from the bottom of the transom would be ideal for the center of the prop shaft?
I moved to the extremely rural north west so small lakes and reserves would be 99% if not all the use it would see. Would a 40hp be sufficient for getting up in a plane and cruising a small boat like this around just for fun or would it just be a put put cruising slow boat?
I own a machine shop/ fabrication shop and building a jack plate would not be an issue.
also I would probably weld up some aluminum fuel tanks for it too.
if the 40 hp is not sufficient for now, how much power would you recommend for having a fun little boat that might go fast enough to scare the timid but not break the bank or set world records
Outboards are not something I havd zero knowledge of so any information would be greatly appreciated.
