First time I towed an airplane at the lake...
SHOCKtheMONKEY
last week at Mohave. Two guys, one getting trained. They shut the motor off and couldn't restart for awhile. Towed them back to the crapper the first time and then to a beach. They thought it was vapor locked. We gave 'em some drinks and snacks while they waited for it to cool down and it finally fired up about three or four hours later and they did a fly by of our houseboat which all the kids really enjoyed.
Another cool day on the water :champagne:
McRib
Is the guy in the last pic peein on the plane?? :p
River911
911 River Trip
Very cool of you :thumbsup
But no fucking way I'm flying in that thing after a 3-4hr wait for it to "cool down" cause it might be vapor lock LOL :skull :D
TBI
Thumbless Wonder
Did they try a different prop?
WTMFA
Kill Em All
C'mon.......wheres your sense of adventure :D
underpressure
That's a first, cool story! I also would be very "apprehensive" (scared to death) about flying away after that....
Chipster27
B Team Member #27
Kids would have probably enjoyed a tow from the plane in a kite tube :thumbsup
River911
911 River Trip
I think we can make it...yeah, just tie wrap the fuel line to the hood hinge and move it away from the exhaust.
Since we're gonna be 7500' in the air, use 2 tie wraps for safety :rolleyes:
WTMFA
Kill Em All
Just follow the river home and we'll be fine.......LMFAO :D
Ziggy
SlumLord
Are life vests required if landing on the lake?:headscratch:
When you towed them did you get them on plane?:p:p:p
djunkie
Broke mo fo
Stories like this aren't helping me make my flying lesson reservation. :D
River911
911 River Trip
Truth be told, if I was gonna have mechanical problems, I'd rather be in a slow stall plane vs a 737 any day of the week :D
TBI
Thumbless Wonder
Can you vapor lock on a treadmill?
Mini Kat
Hammer Makin' Payments
It would have been more fun if i was towing them!:D
Paul65k
Schiada Baby.......Yeah!!
Truth be told this is very common with the Lycoming IO540 in that airplane (lake 250 or turbo). The issue is not the airplane running but the hot start procedure for an airplane with systems that were designed in the late 50's and early 60's.
The starting procedure looks like something designed by Rube Goldberg.....lean the engine mixture to engine cutoff and run the fuel pump for 30 seconds, then with the mixture in cut-off position and throttle at 1/2 to 3/4 you crank the engine until it catches, then you release the starter (left hand side of panel) and you go through a crazy routine of increasing the mixture while trying to retard the throttle so it won't redline the engine, all the while reaching over the yoke with your left hand....because this is a 2 handed operation, OR...................you let the engine cool down, which can take up to 3 hours in hot weather and do a normal start, which does not require the same "cockpit" gymnastics". (That's what the book says to do......believe it or not)
An old guy showed me many years ago how to do it much easier even though Lycoming does not have this written down in any book.....you simply put the throttle to full, prime the engine with the electric boost pump, retard the throttle to idle and start the engine normally bringing up the throttle when it starts to catch......easy peasey!!!
BTW.......now that I think about it that "Old" guy was about the age I am now all those years ago when he told me that, maybe he wasn't that old after all :)
In any case it sounds like the instructor not to mention the student didn't really know their way around that airplane all that well.....at least mechanically!!
Cheers!
Sleek-Jet
Cheers!
Geeze... you make it sound worse that it is. :D
First, that's a Buckeneer so it could have either an O-360 or an IO-360, but I can't read the N number to do a search so see which one.
But for the sake of argurment let's say it's in IO-360... the trick with starting a hot, fuel injected Lycoming is to flood it with the boost pump, then crank it with the mixture an Idle Cut-off. The engine draws air in and when the mixture gets right it'll light right off. Move the mixture towards rich and if it coughs and starts to die pull it back to ICO. If it's to rich the engine will smooth out, if it's to lean it'll just die and you start over from a known condition (to lean to run).
The problem with doing it like the "old timmer" is the way the Bendix fuel injection is metered. You can really flood it and then you are back to the chinese fire drill of throttle WFO, mixture ICO and then the hand dance keeping it going.
Ziggy
SlumLord
I'd prefer just turning the key on and it starting......you guys sound like you're trying to start an old Triumph:p
Flyinbowtie
That is something you don't see every day for sure.
Cool, but I too am gonna question jumping in that thing...Instructor ought to know how to get it fired up, fer crying out loud...
Sleek-Jet
Old Triumphs have more modern technology... :D
coolchange
Lower level functionary
HEY! My old Triumph still starts first kick! Just turn fuel on, wait a few seconds, hold tickler down until you see fuel, count to three. Hold throttle wide open for a few seconds, return to half, pull compression release... oh hell I guess you're right.
LV R SCHIADA'S
funny, a few years back one of those went up in flames on the river, the guys on jet skis tried like hell to douse the flames....she still burned...
SHOCKtheMONKEY
actually one of the guys indicated they just got it a few months ago so they were still tring to figure out all of its idiosyncrasies. I did see the manual sitting on the front seat.
The plane was from Bullhead, maybe somebody knows them???
Paul65k
Truth be told I have not had an issue in over 20 years with any of my planes.....but you have to hit the fuel for like 2 secs max....never flooded and starts like a champ every time!!
Actually you are right and that works too......wow this is starting to sound like a Cessna Pilots/Piper Owners/Beech Owners thread.......I'll go back to boating content now:grumble::grumble:
Sleek-Jet
LOL... I was thinking the same thing. At least we didn't get into LOP operations. :skull :champagne:
Hey... anyone have bikini picks or something?
SHOCKtheMONKEY
Paul65k -
pretty interesting to read the hot start procedure.
My thought was it was flooded by seeing all the black stains on top of the fuselage under the exhaust. There were several stains which looked like something dripped (fuel?) and brought a bunch of black crap from the exhaust with it. The exhaust was a short tube, just like a smaller version of something you'd see on a turbo boat...
WTMFA
Kill Em All
The plane was from Bullhead, maybe somebody will read about them in an FAA accident report someday???
Fixed it for ya ;)
LV R SCHIADA'S
Yeah, just what we want to see due to inexperience, another GA Fatality !!
