sirbob
- Jan 13, 2009
- 10,857
- 15,513
Yeah I was doing a bit of figuring with the limited spec that they give and I figured that they have about 1.5 hrs @ full throttle then your stuck until you have adequate charge to do it again.So you've got 1,000 KW of engines, 800 KWH of battery --- Hmmm, so maybe if you're not running some bumping system and refrigeration, but no AC or other electronics you could get 2 hours at half throttle --- 10 knots. So you average an amazing 20 NM before you kick on the two 65 KW range extenders ???? Solar covers the roof and a few areas, about 130 panels on the roof, so guessing 20-30KW ( or more ??) but that's at solar noon. I think you'd be lucky if you could recharge the batts in a day, I'm thinking more reasonably two if you're using other loads. Plus you need power at night, I dunno, I'm not seeing a lot of "Free Run Time" with this party boat. So batts charged and you take off for another 2 hour cruise --- something doesn't seem right here, so I'm going to pass
