B&w steel.
ThisB&w steel.
I use a Weigh Safe hitch. It's aluminium and comes with 2" and 2 5/16" Stainless balls. It is also available with the large shank size too if your receiver is large (I forget dim 2 1/2"?)
Anyway, the reason I like the weigh safe is for the scale built into the hitch that tells you tongue weight. Not very important for boat but very useful for towing car trailer or off road toys where you have control over load position on the trailer.
Good Luck and hope you enjoy the new truck, congrats!
I use this one also as I needed a bigger drop then B&W had avaliable. Can't go wrong with either both very well made.I use a bullet proof hitch. Seems to work really well mines rated for 20k.
Whats the drop on that hitch? I was thinking about getting the B&W but cant decide on the drop. I'd prefer 7" just for flexibility in heights but am concerned that the drop will scrape. I am putting it on a 2500HD Z71, similar to your trucks height I think.B&W Stow and Go View attachment 729374
They offer a few variations of drop or raise with the stow and go series.Whats the drop on that hitch? I was thinking about getting the B&W but cant decide on the drop. I'd prefer 7" just for flexibility in heights but am concerned that the drop will scrape. I am putting it on a 2500HD Z71, similar to your trucks height I think.
This is what I use. My only gripe was it only comes with one bumper plug..... So I bought extra bumpers to eliminate having to move it every time I adjusted the height. Other than that, great hitchI have used the Curt 45900 20k lb adjustable steel hitch for about 5 years now. Has 2” and 2 51/6” balls. Great hitch.
I bought a 2019 f250 4×4 and put a leveling kit on it with 35" tires. I need to purchase a new drop hitch to tow the boat. What are you guys using these days for this kind of set up? Aluminum or steel?
Are you talking about the set screw bolt in the backside to keep it from jiggling? If so, I don’t ever change the height of the balls, I only swap it between sizes.This is what I use. My only gripe was it only comes with one bumper plug..... So I bought extra bumpers to eliminate having to move it every time I adjusted the height. Other than that, great hitch
Sent from my FRD-L14 using Tapatalk
Aluminum, adjustable, 2 5/16 and 2" balls. Very handy because i tow multiply trailers.
That’s what I use too. I have the 2” shank version and my dad has the 2.5” version for his F650I have used the Curt 45900 20k lb adjustable steel hitch for about 5 years now. Has 2” and 2 51/6” balls. Great hitch.
With the fatigue factor of aluminum, why do people bother with them? Cheaper?
Stay away from Trimax Adjustable aluminum locking hitches. The locks are junk. Nothing like not being able to unlock the balls to switch sizes. I just dealt with this today.
I ran a Rapid Hitch for years and liked it. I think they’re called Anderson now.
You'll like it. I've been towing 5 different trailers over the last 2 weeks.Thanks for the information on here. I just purchased a B&W 7 inch drop. It has a 10,000 lbs rating and great for what I need. Headed to the lake next week for a trial run.
Don’t forget to grease the ball Dave
How necessary is this stuff? On a scale of 1-10, 1 being Not Necessary Ever In Your Lifetime, and 10 being You Need Air To Breathe, this ranks as a 2.
Do I have to grease my ball regularly?
Only when it looks like it needs grease. If chrome starts flaking off your ball you should have greased it 6 months ago.
Am I stupid for buying this small container of ball grease for $10 instead of just using leftover axle grease?
You appear to have been sucked into a $10 grease purchase by marketing jargon. Any axle or marine grease will work fine.
Answers are line, in ORANGE.
