Driveway concrete repair experts..
Should he stated right off the bat I’m not mad.. myself and friends drink a little bit and we had one crazy night..
Unfortunately my driveway is looking a little rough now.. lol
Is there anyway to fix this other than busting out the slabs and replacing? And if I do that, is there anyway to even kinda halfway make it match?
There’s two spots on two pads where a one wheel wonder burned holes through the top of it.. It was a hell of a burn out though.. lol. Or rather burnouts.
Nordie
Nothing will ever match. Might be able to do an overlay, or have the driveway ground a little bit to mask it.
Give it a summer and some pressure washing and it won't look as bad.
outboard_256
I say 10 more of those around the drive way and it will look good.
HNL2LHC
View attachment 1083427 View attachment 1083428 View attachment 1083429 View attachment 1083430
I’d just line up the cars again and do another round of burnouts. That way no one knows that you and your friends can’t do a real burnout. 👍
Ok.. that’s about what I thought but I was hoping for some kinda miracle cure..
HB2Havasu
If it’s bothering you why not just bust it all out and replace with concrete paver driveway? Looks so much better than poured concrete!
Now if it was a rental property I would just grind off the rough edges and call it good!😬
v6toy4x
Patchcrete is what we use to patch our slabs and tiltup panels, matching existing concrete is near impossible, if you float the patchcrete out it will "feather-in" kind of like touching up a painted wall, the further out you get the less product is applied and it slowly disappears.
ltbaney1
you could acid wash it, it will etch it though. ask your pool guy about. my buddy does pools here in so cal and acid washes patios and driveways on the side.
Jim
It will fade some with time.
Give it a year of weather.
Ladsm
Have a epoxy floor contractor come in with a diamond tip grinder and grind the whole driveway and then seal it. It will expose the rock and add character to it. Maybe work the RDP logo into it as well and write it off as a business expense for advertising.
Activated
Deplorable
Dawn dish soap and a scrub brush will at least take out the rubber marks.
After that, it might not look so bad.
BingerFang
Rookie move... Always do burnouts in the street Dave!!!
Desert Whaler
It's like a Coyote Paw Print in a Saltillo Paver . . . it's considered good luck ! 🤣
gqchris
Looks like the spot I have on mine where my drunk dumbass lit some fireworks on a 4th of July without any bottom protection. Im sure heat is the same culprit. Shit never has come out 4 years later!
Jed-O
Shitter was full!
RD, get a hold of a local water proof deck contractor and tell him you are interested in the "Life Deck AL system" as an overlay.
It's a lightweight concrete mixed with 100% acrylic and adheres to just about anything including the trowels putting it down. They should be able to patch the holes and then do the texture coat over the whole driveway. Skip the final color coat so that you won't have to worry about maintenance.
Ziggy
SlumLord
A little before your time, but it used to be hold my Bud Light Lime and watch this!!!
Lol, that was a short lived addiction before remarrying the Silver Bullets😄
I did some a few years back, did some with taped lines as well, gives the finish look of sandstone pavers. Different ways and looks to get. Some "cool deck" types as well.
Joker
At some point the coating will get gouged and he’s going to be right back where he is now.
pixrthis
Time for stone ribbons throughout the driveway
DaveH
there are companies that have machines to grind it down (the entire driveway). will look brand new once complete. probably take a 1/16th or more out of it.
