Does Blythe I-10 check quagga insp?
ltbaney1
the last few times i have towed through there, IF they are open they look. but i have never even had the guy bend down to look just has me pull forward and then waves me on.
brianwhiteboy
Professional Lurker
Rolled through there Friday night. He just checked to see if the plug was out and sent me on my way.
DarkHorseRacing
Clean, drained and dry and they won’t care any further than that.
jesco
Typically if plugs are out they will wave you through, and best to not have water dripping out... and make sure you don't have any grass sandwiched between the hull and bunks or wrapped around the trailer at all. They will stop you for that and make you try and clean it all off.
SOCALCRICKETT
Jump across the Agnes Wilson bridge, Geoff. Run down the California side of the 95. It bypasses the Agricultural Inspection all together.
^This
I work in blythe and I don't even bother taking mohave rd through erhenburg, mainly because I know if something goes wrong it would be the guys from my station responding to the accident and we are only 30-40 minutes out, not an hour plus like it would be going the arizona side
DWC
Never been checked before. They want plugs out. May check for a wet anchor. No real check though
