- Sep 4, 2015
- 49,689
- 76,177
Because I'm cheap I decided to put together my own helmet blower for this offroad season instead of buying a "kit". You can set this up as a single port, dual port or even quad port blower. It is a basically a copy of the PCI Race Air "Big" 150 CFM blower setup they offer in 1, 2 or 4 port. You'll save anywhere from $60-100 on just the pumper depending on what price you find the blower itself, and what accessories and funnel (port count) you choose. This dual outlet pumper I assembled is $250 from PCI. I have less than $150 into my pumper, and it is basically identical.
I found a Jabsco bilge blower on Ebay for $70 shipped. Model number 36740-0000. This is a 150 CFM, 12 volt blower, with 3 inch inlet and 3 inch outlet. There is also a 105 CFM version available. PCI uses that one for their lower end single outlet pumper.
For the inlet you can use any 3 inch air filter. PCI actually does have a nice filter for $16, so I just used theirs. You can get a filter that has a stud in it that uses the traditional spun aluminium dog dish cover, Or get the same air filter with no stud, and run an outerwear prefilter. I chose the prefilter route as I am not worried about splashing water, and not running the dog dish makes for a lower profile package. The dog dish is only there to protect from water. The PCI branded prefilter is more expensive than a generic "outerwear" one you can find on amazon or wherever. But it fits their filter perfectly so I bought it.
Now you need the outlet or "funnel". These can be fabbed up if you have the materials and the time. The single person funnel is like $15 so just buy it from PCI. The dual outlet funnel I got is $26, I think the quad outlet is $40 or something. All the PCI funnels will slide right onto the blower outlet. You can drill through the funnel and plastic housing and secure your funnel with a screw or rivet after you slide it on the outlet. I would do this in at least 2 places.
My pumper ready to go with the filter, prefilter and black dual outlet funnel. They also have a silver outlet funnels that are a bit cheaper than the black ones.
For reference, this is the PCI pumper with the SINGLE outlet funnel and dog dish air filter guard if you like the dog dish instead.
Then you are pretty much ready to mount the pump and go. The pump comes with a mount to bolt the pump to a flat panel, like in the bed of your SXS. If you want to mount it to a roll cage, PCI offers billet mounts for $99. They are nice, but overpriced. Parker Pumper offers a billet roll bar mount for their pumper for $35 that will fit. I have that coming to verify, but their motor is the same size as this one, so it should work perfect.
Link - http://www.parkerpumper.com/shop/parker-pumper-motor-mount-b9xad
You want to choose ORIGINAL for application, and choose the appropriate size roll bar for your machine.
Parker Pumper mount
Parker Pumper mount in a car. Our pumper here would mount in the exact same way.
Here is an example of another cheap mounting option. This uses the factory steel panel mount that comes with the pump, and you simply buy some straight light bar mounts for your specific roll bar size on Amazon. These mounts are usually $15-$20 a pair. Add some hardware, and you are ready to go.
Once you have your pump mounted, you need to measure for the helmet hoses (Kartek has reasonably priced helmet hoses) that will run to your helmet. Remember to add a foot or two of hose slack here so you can get your helmet on and off if needed, and also so the hoses are not pulling on your helmet. Then wire up your pump to 12V with a fuse and a switch to turn the pump on and off, and you are good to go.
All in you should be around the same price as just buying the pumper alone from PCI!
Parker Pumper mount
