curbless showers, has anyone done it?
sintax
So I live in a late 90's build home, it has a fairly decent sized en suite bathroom. It seems most of the homes in this era have these tiny tiny stall showers, and these massive tubs. Mine is back to back, shower / tub, all along the exterior wall, on the second story.
I'd love to totally ditch the giant tub (yes, i have a second one in the guest bath), and build a nice big shower, ideally curbless.
Has anyone gone down this road? Any regrets?
I do understand that choosing the right "system" is important when you're dealing with a wood subfloor, so wanted to see what peoples experiences have been.
Anyone have any recommended contractors / installers?
lf2
I did one for a customer a few years ago. Used the Wedi system, came out nice.
sintax
Awesome, looks good. Do you install in Corona / Riverside area?
sintax
If you haven't already considered it, I would suggest looking into a linear style drain. Will make slope and tile layout a little easier.
I have no connection here. Just an example.
Yes, this was on my radar for sure.
I have done them. To far from me. One was for a elderly customer. We made it where the helper could wheel his wheelchair right into it. Linear drain is way to go. If raised foundation or second story the framing needs to be dropped for proper slope.
RichL
^^^^This^^^^
Jed-O
Shitter was full!
A buddy of mine (a fellow contractor in arrowhead) did one for a charity job several years ago for a disabled couple. He had to cut out the floor joists and re-frame the subfloor 4" below the original and fully waterproof it with a hot mop membrane over bituthane. Then he pitched the entire floor to the shower drain and tiled the whole thing. It was a huge undertaking and if it hadn't been a charity deal with a ton of sponsors it would have cost the owners close to 90K.
white tortilla
If you were in first floor with conventional slab it would be easier to do you could saw cut the slab and set it lower. On second floor it’s more complicated. For a decent size shower your going to probably take 4” out of your floor joists and even more at the trench drain if you did that. Would need someone who knows the loads of the joists and how to correctly beef them up onto bearing points below. I would strongly suggest going with typical shower with a curb it will probably cost 1/4 to do framing and rough changes then trying to do curb less.
lf2
With the Wedi system (schluter and others have come out with similar setups) you block and flush mount the subfloor with the top of the joists, no joist cutting or re framing needed. Then pan installs and is level with original sub floor.
can you post more pics that looks great! What a cool bathroom!
Is the rock wall tile the 12x12 sheets?
QUOTE="mjc, post: 3999434, member: 903"]
Just finished mine. 4 ft linear drain
[/QUOTE]
sintax
With the Wedi system (schluter and others have come out with similar setups) you block and flush mount the subfloor with the top of the joists, no joist cutting or re framing needed. Then pan installs and is level with original sub floor. View attachment 967728
This is what i've seen as well. I know technology is always changing in this area and thats why I reached out.
badluck
Did this 1 about a year ago. Lowered the floor 3”
mjc
Retired Neighbor
[/QUOTE]
This is all I have
They are 12x24 tiles floor is 6x6. I had to take out 3 to 4 inches of concrete to do the pan. Put the shower valve on opposite side of shower head.
77charger
As one who waterproofs the showers my advice it thismake sure when its built you sink it down far enough i cant tell you this enough.
Need to sink subfloor minimum 3 inches any less you risk water flowing back to the rest of floor outside.Your drain is about 2 inches high i add about 1 in to 1.5 of slope tile guy needs room to float and tile too.Cant tell you how many times i show up guy has only sunk floor about an inch i tell them it wont work they say im gonna do this and that it water wont run out,i cant go any lower because iit wont work etc.I stand back quietly grab a level set it on top of drain and just say this is where water is suppose to go first and its about an inch higher than the outside floor i then tell them add tile float and tile they will be above rest of floor and raising the rest of room and most important water will be running out.I dealt with shea homes they tried to throw me under the bus on a tract trying to explain to ego filled supers doesnt work then when it fails they change storie glad i documented it.
jeteater1
Jet boats suck
This is all I have View attachment 967755 View attachment 967756
[/QUOTE]
Wife and I are going doing the same looked once I save some more money.
Reactions: DWC
HNL2LHC
We did ours 4 years ago in our basement addition. Sorry these are the best images being that it is a small area. We will be doing it again in our Havasu house starting next month. Going to pull the shower stall, break up concrete, reset the plumbing to include a linear drain and then build it all back up.
lakemadness
Grobe Bruste Bitte
I’ve put them in many flip home we’ve done. I put on in our last personal home. No issues at all. If the drain is slow that could be an issue.
Our new house had the bathroom updated not too long ago. It has a curb and I miss the curb less walk in. We renovated 100% of the downstairs, next is upstairs and curb less it will be.
I sold one of my flip homes to some unicorns (hot lesbians) it had a 6’x6’ curb less walk in shower with multiple jets and rainfall head. Damn I can only imagine how they broke that shower in...
HBCraig
Curbless? What do you mean? I honestly don't know what you are referring to
Are you talking about the drain?
mjc
Retired Neighbor
mjc
Retired Neighbor
No stepover to get in the shower. Flat with the rest of the floor just a slope to thecdrain.
Mandelon
Coffee makes me poop.
HydroBlok makes presloped pans for linear or center drains. Super simple. Like the Wedi system.
We have done many of these. Making it work with those Silent Foor I joists is a pain!
You need to put on plenty of sealer with that stone tile. Hard water and soap deposits will make it all white if you don't.
And maybe even if you do.
sintax
do you work in the Corona area?
Gelcoater
upstairs? Or down?
sintax
upstairs? Or down?
upstairs my man! You know I like to live life risky....
haha I don’t know if it’ll make sense, but I gotta do something and I’d like the curbless if possible.
Gelcoater
Is the only floor I’d consider living where we do.
On a downstairs application, and is being in septic systems?.... I see potential for a very shitty situation going curbless downstairs.
77charger
Another hint i can offer is that say you want it 3.5x5 and most i think will set glass on the 3.5 mark.Maybe make the sunken part 4x5 you wont notice it from the top then still set your glass at 3.5.
What this does is makes your showerpan bigger underneath and when water hits the glass it will fall down and some will go through the grout which will sink into your waterproofing.Its a minor thing that can make a big difference.Like someone mentioned the linier drains are taller,I referenced your standard type 2 piece drain which are about 2 inches in height the linier type can be about 3 or more.You will need to sink down the floor a little more for one.I think a tile guy can answer that one better but wherever it is you do want the top of drain to be lower than the bathroom floor i want to say atleast an inch?? or depending on where drain is 1/4 inch per foot??(like said on drain i aint sure)I only know the damn waterproofing part and how to make sure its water tight LOL.
Yeah that would be my first thought as well, make sure the thing has excellent slope, it wouldn't hurt to have the tile guy float the next couple feet out of the shower with 1/4" to a 1/2" slope in the the right direction just in case any water did make it under the door it will eventually find the drain, not the rest of the room.
badluck
I recommend a shower door. Our didn’t need 1 but it’s freaking cold/drafty without it. I’ve always been a fan of hot mop but I could not get anyone to do it here so I did a liner on top of my sloped plywood floor then I floated it and put red guard on top of that. Not a fan of the red guard product. It’s really difficult to tile a floor using 3” or larger tile with significant slope which I highly recommend when going curbless. I opted for 2x2 tile
lf2
1/4” per foot on a standard 3x5 shower with center drain is only 5/8” drop. The drains used with these kits are way lower profile than the stuff you use.
