Cleaning an oil cooler
Tooms22
On Vacation
So I'm having my motor rebuilt after it self destructed (metal pieces throughout). The builder informed me that I need to get my oil cooler ultrasonic cleaned or purchase a new one.
Does anyone have a recommendation for a company in OC or the Inland Empire that does this? Based on replacement cost for my oil cooler, I'd prefer cleaning over replacement if possible.
OLDRAAT
inadequate member
Buy a new one. Why save a hundred dollars to risk thousands.
Years ago when in the metal finishing business, I tried cleaning one better than a radiator shop. Hot alkaline dip, acid dip etc, etc along with a ultrasonic cleaning and it wasn't perfect. FOD was not that much and would have been probably ok for general use, but if you have a performance motor ($$) buy new. There are several direct heat exchanger suppliers that have many marine models less than the OEM (or supply to the OEMS).
Good luck.
OLDRAAT
inadequate member
To add, if it's not a visual priority, you can get a new one at the proper size unfinished, then rattle can or powder coat and save some bux.
OLDRAAT
inadequate member
See if Mister Cool is still in business.
mrcool.us
Welp, with those two replies... does anyone have any suggested replacements?
I'll keep this expense off the books and away from the wife :D
Just take a zero off the price you paid when she asks how much it was.:D
guest hs
Take it to a radiator shop and have it boiled out.
Jed-O
Shitter was full!
Add an inline oil filter after it for the same price as a new cooler. At least you might be safe :D
ElAzul
Well-Known RDP Inmate #211
Chuck it, I scattered a trans, had the cooler and lines cleaned only to pull it all out and do it again
Carlson-jet
Not Giving A Fuck Is An Art
The age of the "Heat exchanger" is to me the critical question. If it's 10+ years old, buy new.
Clean and pressure test Properly or buy new is the 2nd question. Done properly one is just as good or I will say gamble as the other.
Knowing, building and maintaining the machines and running them in the manufacturing process from all raw materials to finished heat exchangers, I know new is no guarantee against scoobies or failure.
I would clean it and run knowing I was in charge of the process. I wouldn't drop it off at billy Bob's radiator and taco stand and expect the same results.
If I bought New, I would clean it just as if it had been beat like a dead horse.
rush1
Don't clean it throw it away ,you can never get that metal out of them.Why spend all that money on a new engine just to screw it up with a dirty oil cooler
Tooms22
On Vacation
Ok school me a little. Does it have to be the same exact dimensions? Is there a suggested size for a BBC?
obnoxious001
Engine building character
It may be possible to clean it, and use an inline filter after the cooler for insurance. Canton makes some that filter down to 8 microns. I can also get you a new block mounted Olson cooler that would clean up the installation a bit.
Tooms22
On Vacation
I'll do whatever you think is best. I hope to not think about rebuilding a motor for a long time after this.
welldigger00
I’ve made this mistake before. Second engine turned into the third engine.
OLDRAAT
inadequate member
It should be at least the same size as the current one. Don't go overkill unless it's a t-stat controlled one, you want the oil to be within the proper temp range.
rrrr
Having a thermostatically controlled vernatherm valve on the oil coolant loop is a key ingredient for proper engine temperature control. When the availability of an endless source of coolant is paired with a 10 micron filter, engine life can be greatly extended.
This thread prompted me to search for the various types of oil coolers available, and I'm surprised that just a few of the coolers on the market have removable end plates on the shell. That would allow periodic inspections of debris screens and cleaning.
Boat 405
Buy a new one, trash the cooler and lines. Also up size those oil lines to -12 all around. -08 or -10 are too small you'll get quite a bit of restriction.
Don't forget the lines and fittings.
