Hi all,
Clearly new to the game here. Besides the obvious, what’s the difference between a circle and a drag boat and can a circle boat be a good lake boat?
Hi all,
Hi all,
A circle boat will be a solid lake boat right of the trailer, in most cases.
Drag boats were meant to run for a VERY limited amount of time. You'd probably have to do a LOT of mods to make a boat that would run all day out of a drag boat.
So say's the OG of pontoon boat owners.![]()
Thanks for all the responses! My goal would be a lake/river cruiser boat. I was thinking circle boats were setup with the backward engine and perhaps a few other things that made the boat turn easier/faster and maybe only turn left.
That didn’t sound like a good lake boat set up. My goal would be to mostly cruise the river between Davis dam and the sand bar. Is a blown, carbed engine that can Run on pump gas to much to ask for?
Thanks for all the responses! My goal would be a lake/river cruiser boat. I was thinking circle boats were setup with the backward engine and perhaps a few other things that made the boat turn easier/faster and maybe only turn left. That didn’t sound like a good lake boat set up. My goal would be to mostly cruise the river between Davis dam and the sand bar. Once in a while on Lake Mohave and Havasu but only in very nice water. Slow cruising is fun but so is going fast once in a while. Is a blown, carbed engine that can Run on pump gas to much to ask for?
The problem with this question is it leaves out a ton of variables. Flat bottom boat building spans 7 decades. A 50's drag boat is worlds apart from something being layed up today. So hull design, weight, rigging and power all play a part in the equation on both sides of the fence.
For the question to be answered properly, you need to take each boat individually and break it down. You can't just say drag boat or circle boat without getting more specific.
That brings up a solid question, I know that there has been hull and bottom development in the last 20 years on flats for drag, but what about any major development on bottom design for the circle guys? Theres still a few guys popping out b-boats, but is there enough demand for change?
