going to be some long ass turnbucklesFinally got a few hours today to get my Spectra back in and start mocking up the cavitation plates. View attachment 916625 View attachment 916626 View attachment 916627 View attachment 916628 View attachment 916629
Which gap are you talking about?Why do you have a gap? Or is it not permanent?
That’s no lie !View attachment 916639 long turnbuckles are just eye candy on a beautiful ass!
The gap between the cav plates. I see that your drain plug is off center as well.Which gap are you talking about?
Are the plates stationary? I guess I haven't seen a gap like that except on squirters with a ride plate under the bowl. She is beautiful to say the least. love the deep blue! As you see on my Schiada it is hinged without the gap.Drain plug was already there and off center. The plates are in the same location on both sides
Are you talking about the gap in the middle between the plates? These plates are not stationary. I didn’t want to do a hinge like a trim tab I wanted it to move more like a real cavitation plate not a trim tab. The 24 Spectras didn’t have a recessed bottom for cavitation plates they used Bennett trim tabs. In my opinion a Vdrive boat is not a Vdrive boat if it doesn’t have cavitation plates!Are the plates stationary? I guess I haven't seen a gap like that except on squirters with a ride plate under the bowl. She is beautiful to say the least. love the deep blue! As you see on my Schiada it is hinged without the gap.
My OG cavitation plates aren't recessed either and are original 1970 equipment, IMO a true cavitation plate needs to be able to put down force on the water to bury the nose to stop porpoiseing and to turn more efficiently. Sure things have changed and upgraded since new technology has come into the picture but still don't see how those plates can change pitch to exert down force. They look like they just make the keel longer. I will continue to watch the progress of your post cuz I am very intrigued on how that's supposed to work without a hinge Where is the actuator hole?Are you talking about the gap in the middle between the plates? These plates are not stationary. I didn’t want to do a hinge like a trim tab I wanted it to move more like a real cavitation plate not a trim tab. The 24 Spectras didn’t have a recessed bottom for cavitation plates they used Bennett trim tabs. In my opinion a Vdrive boat is not a Vdrive boat if it doesn’t have cavitation plates!
Can we spectator's get more pics of your beauty, interested in the prop and rudder, from the angles shown ww can't see the bits and pieces. ThxFinally got a few hours today to get my Spectra back in and start mocking up the cavitation plates. View attachment 916625 View attachment 916626 View attachment 916627 View attachment 916628 View attachment 916629
This is just a mock up stage before I send them out and have them polished. I still need to install all the turn buckles the control rod the actuator arm etc. Remember these are not trim tabs they are cavitation plates there’s a big difference. How many flat bottoms have you seen that have a hinged plate? Probably none. The point is to create a concave in the bottom of the plate verse a trim tab that just goes up and down on a hinge. I guess you will understand when I’m doneMy OG cavitation plates aren't recessed either and are original 1970 equipment, IMO a true cavitation plate needs to be able to put down force on the water to bury the nose to stop porpoiseing and to turn more efficiently. Sure things have changed and upgraded since new technology has come into the picture but still don't see how those plates can change pitch to exert down force. They look like they just make the keel longer. I will continue to watch the progress of your post cuz I am very intrigued on how that's supposed to work without a hinge Where is the actuator hole?
I haven’t installed the rudder yet once I get it in I will send more picsCan we spectator's get more pics of your beauty, interested in the prop and rudder, from the angles shown ww can't see the bits and pieces. Thx
Do you know if they did any bottom work on the hull when they re-gelled the boat? (Like remove the hook at the back). Looks great! Keep the photos coming!This is just a mock up stage before I send them out and have them polished. I still need to install all the turn buckles the control rod the actuator arm etc. Remember these are not trim tabs they are cavitation plates there’s a big difference. How many flat bottoms have you seen that have a hinged plate? Probably none. The point is to create a concave in the bottom of the plate verse a trim tab that just goes up and down on a hinge. I guess you will understand when I’m done
There is some more pics in the Spectra sectionSo what’s up with this @namba860 is there another thread somewhere or did you just get busy with work and stuff. I like these kind of threads.
I’m running 1 3/4 long control rod ends.It looks to me like you will need to have longer blocks to hold the control rod. The angle from that rod to where the pads are looks pretty steep?
The boat is a1974 I have put a straight edge on the bottom and there is no hook in it. Yah not sure why the plug is off center kinda bothers me but I have a budget to stick to and that isn’t really a priority.I like the colors of the boat and am looking forward to following your project. I may have missed it, but what year is it? That drain plug being off center would bug the sheeit out of me. I couldn't have left it alone. Did you guys do any bottom work to the hull, or was it blue printed by the previous owner?
I made a full length shim that went behind the mounting bracket where they are bolted down it makes the plate level with the bottom
I would Love to see bottom view pics, please and thank you.All done on the outside just need to mount an electric motor to the plates View attachment 956492
