Campbell 20’ Whaler
beaverfab
Picked this boat up in October in Yuma, this is a picture of it on the way home.
beaverfab
Removed the name sorry to the previous owners but not my style.
Brokeboatin221
Cool and rare build, it’s crazy how close the gel/wood is to my Howard it’s as if the same person did them which knowing boats in the late 70s I bet they did. Can’t wait to see her finished keep the pics coming.
wettrthebettr
Nice Catch, Tearing out Rotten Floors, You have your work cut out for ya.
With it that rotten made the removal a little easier.
What year is that Whaler?
Keep us posted on your resto.
beaverfab
1974, polished all the old hardware most came out good hoping to get the new seats next week . Engine BBC 454 with small camshaft, 9.5 compression , turbo 400 tranny, 9% over in the V-drive. Hopping for speed in the 50’s. Boat is very very heavy, 12” stringers.
rider68
Awesome boat. I just picked up a whaler that is a splash of a howard. Did you build that swim platform? I looking at getting one for my boat. If you did build it what dize material did you use. I will be watching your build.
Sent from my LG-G710 using Tapatalk
beaverfab
Sorry photos not in order. Got the boat ready to take to upholstery guy after waiting 4 weeks had boat there Monday’s 8:00am was thinking 2 weeks. Well 2 days later at 9:00 he calls he tells me come pickup your boat ??
Ok then he tells me he does not know how to do what I want? Well Sxxt. Now every upholstery guy tells me there 4 to 6 weeks out. So bring the boat home grab some cardboard and start cutting, how hard can this be? Have patterns, now what. I am a machinist not a carpenter so how do I get the backrest to hold the shape I want? Have a friend sheer some aluminum to size, then use my metal roller to shape it, problem solved. Drill and tap 10-32 holes in the boat and that’s done. Weld angles to the bottom of the aluminum and now I can attach the seat bottom. Cut the wood for the seat riser and now I have seats. Trip to upholstery supply $600 later I have material foam and other things I need. Years back I acquired an industrial sewing machine for my wife so now its time to practice my sewing.
beaverfab
Ok so on to the upholstery going with red and white just not sure what is going to be red and what is white.
beaverfab
Stoped on the upholstery for a little while getting the engine ready 454 BBC cast iron heads 10.7 to 1 small cam . Hope to put it in the water end of the month.
wettrthebettr
It's moving along, looks great , what Exhaust manifolds are those? I have never seen one all solid like that with the riser and manifold all one.
beaverfab
PFM made some and others PFM were used with twin turbos. They came with the boat I am installing mufflers will have pictures later.
beaverfab
Engine and transmission are in running short on time 13 days till I want to be in the water.
beaverfab
Finished welding exhaust, wiring is 90% finished, had to make a new prop shaft seal housing .
beaverfab
Ok back to new pictures have motor finished except for fuel line and mounting oil filter. Had it mounted to the head but the seat hit it so morning it to front of motor. Painted some more of the floor . Started to reinstall the seat bases. Made the cover for the front storage box it is for an anchor.
beaverfab
Finely got the interior most of the way finish now only the floors remain.
beaverfab
A little more progress
Long Way Home
Dog Days of Summer!
It's Looking good, I have always like the Whaler style boat.
beaverfab
She on the river runs good couple problems tachometer and water timp not working , but no leaks .
Outdrive1
Was this @PinkTaco ‘s boat?
caldezrat
Beautiful. I've always liked the v-drive wailers.
