Jonas Grumby
The Skipper
- May 4, 2010
- 3,014
- 4,103
Anybody heard of this? Any good or is it snake oil?
Aviation guys seem to swear by it.
I have cases of ZDDP that I use in my Roush motor in my Cobra.I use ZDDP in my flat tappet engines
CamGuard was developed because of a construction feature particular to Lycoming opposed cylinder aircraft engines that creates cam and lifter face corrosion and failure. It can also occur in engines manufactured by Continental. The cam is located in the top of the engine case, above the crankshaft, and is oiled by splash lubrication from the crankshaft rotating assembly.Anybody heard of this? Any good or is it snake oil?
Makes 100% sense.CamGuard was developed because of a construction feature particular to Lycoming opposed cylinder aircraft engines that creates cam and lifter face corrosion and failure. It can also occur in engines manufactured by Continental. The cam is located in the top of the engine case, above the crankshaft, and is oiled by splash lubrication from the crankshaft rotating assembly.
Because these aircraft engines can sit unused for long periods of time, two things occur. One, the oil on the cam and lifters drains away. The other is that atmospheric moisture collects in the top of the engine case, and ambient temperature changes cause the moisture to condense on the cam and lifter faces. The condensation attacks the wear surfaces of these parts, and over time, it initiates corrosion that causes failure due to scoring of the cam face and spalling of the lifter friction surface.
CamGuard additive was developed to promote adhesion of the engine oil to the cam and lifter faces, and additives in the product reduce the ability of oxygen and moisture to attack the part's surfaces.
Use of CamGuard in a normally driven automotive engine would provide no discernable benefit to cam and lifter preservation. It could help protect the parts in engines of vehicles that are infrequently driven from corrosion for the same reasons I listed above.
I know you guys think I use Google to write this stuff, but it just drips out of my brain.
Yeah, zinc is not good for cats.If it has zinc...
And your engine has a catalytic converter behind it ...
Using it would be a Really bad idea.
The combustion of a gallon of gasoline produces copious amounts of water. Some of that escapes into the crankcase through piston ring blowby, which can be exacerbated by PCV systems drawing crankcase air to the top of the engine.Makes 100% sense.
What are your thoughts on using it in an overhead cam V8 like my 4.7 2UZ-FE Toyota V8 Motor (2006 Tundra) ?
On one of the Tundra forums they noted a similar scenario you described above, which can be 'somewhat' experienced in these motors.
Apparently a good amount of 'sludge' can accumulate under the valve covers in the Gen 1 Tundras which
are primarily used for very short trips.
The working theory is that the motor heats up, then cools when turned off drawing moisture / condensation in.
Repeated short start /stop cycles like this don't allow for a proper 'burn off'of the moisture , thus resulting in the sludge accumulation.
The cure is to run the motors for longer periods, and be diligent with oil changes of the recommended 5w-30 synthetic at around 5K miles.
When shopping for Gen 1 Tundras, some believe a very 'low mileage' truck from 2000-2006 has it's own set of problems, the sludge build up being one of them.
Sounds like it would be good for a boat or truck that sits weeks at a time between starts?CamGuard was developed because of a construction feature particular to Lycoming opposed cylinder aircraft engines that creates cam and lifter face corrosion and failure. It can also occur in engines manufactured by Continental. The cam is located in the top of the engine case, above the crankshaft, and is oiled by splash lubrication from the crankshaft rotating assembly.
CamGuard was developed to promote adhesion of the engine oil to the cam and lifter faces, and additives in the product reduce the ability of oxygen and moisture to attack the part's surfaces.
If the vehicle isn't driven long enough for the oil to be heated above an elevated temperature, the moisture is retained in the oil. This is repeated over short trips. As the aluminum cylinder head cools, the moisture is drawn into the cam cover and condenses. It reacts with other combustion products to form acids and the sludge you mentioned.
To minimize this condition, avoid short stints in the vehicle whenever possible, as you said above.
CamGuard would not be of any benefit.
Yes I know, but it’s got to build pressure. If this stuff makes the oil stick to surfaces, sounds like a good thing during startup?That high tech airplane engine relies on splash oiling from the crankshaft to lube the camshaft. Much like a 216 Chevy 6 (1940's technology)
Sbc's (1955 up) and big block Chevy's (1965 up) have full pressure oiling, including the cam and lifters.
Extra fancy ZDDP wouldn't hurt in a flat tappet boat, but isn't necessary.
Just running a quality oil is sufficient. I use Delo 400 15/40 (higher ZDDP content) in all the flat tappet engines. And some roller ones too.
Dan'l
There hasn't been any significant research or documentation I'm aware of regarding the use of CamGuard with automotive oils and in automotive and marine engines.Yes I know, but it’s got to build pressure. If this stuff makes the oil stick to surfaces, sounds like a good thing during startup?
