ChiliPepperGarage
Well Known RDP Cart Returner
- Mar 8, 2008
- 4,471
- 10,332
I've got a 2008 Chevy D-Max 2500 and want to run 35's on it. This truck will not see any hard core offroading, mostly dirt roads and mild trails. I am setting it up for camping / "overlanding". It currently has a leveling kit with CST upper control arms on it and while it is mostly fine on pavement (actually handles curves very well), it rattles my teeth out on dirt roads.
I see BDS has a new coilover conversion kit which also lowers the diff to straighten out the axle shafts but it costs $4700 not including install! It does come with Fox 2.0 shocks which I know are good but that's a lot of $.
A BDS 4" lift is $3,600 installed by the local dealer in Reno.
Another shop quoted me $3,000 installed for a Rancho 4". Not sure about Rancho quality.
I'm waiting on a call back from my local 4 Wheel Parts dealer.
I ran an RCD 6" on a 2500 Chevy before and was very happy with it. Very smooth, stock like ride. I ran a CST on another truck too.
Looking for input on other lifts. The BDS kit comes with brackets that keep the torsion bars up in stock location instead of sticking down like other kits. Not only looks better but also one less thing to get hung up on stuff. The Rancho shop said that they put more strain on the upper control arms though. Don't know if that is true or not.
I purchased a set of Bushwaker Cut Out fender flares and will be doing the NorCal mod (opens up the stupid square wheel openings 1&1/2") with the intentions of leaving it at its current height but am sick of the harsh ride. I want to keep the lift to a minimum to make getting in and out of the back as easy as possible. I will also be getting a new front bumper that will provide more front tire clearance.
Here is the truck as it currently sits. I don't know how much higher than stock it is as I bought it with the leveling kit already on it. Tires on there now are Toyo Open Country 285/70-17's but are about worn out and I want to run 315/70-17's which are actually about 34" tall.
