Best desert tire for a rzr XP4 1000 ?
Bigbore500r
Getting ready to do tires and wheels on my ‘17 XP4 1000. Don’t want to reclutch, or stress out the belt / stock suspension components (more than they already are!)
We ride desert, not a lot of rocks but we do crawl up trails littered with small jagged stuff occasionally.
I’ve heard it’s best to stay with a 30” tire on the non-turbo cars, and have also heard that a tire with a rounded tread profile is easier on the car from a durability standpoint, compared to say a tensor with a flat, square profile.
Also - 14” vs 15”, and offset?
What say he? Have a few friends running motohammers, without issue. I was looking at motohammers, mongrels and tensor regulators mainly.
riverroyal
riverroyal
These are on stock can ams maxxis liberty
On the desert rock edition
c_land
Just ran the Arizona Peace Trail last week with a group of 7 RZRs. Over 700 miles the four RZRs with the BFG Rzr tires and Tensor Regulators were the only ones that did not have a flat. All those cars were running 13 PSI and we weren't going slow.
The four with ITP, Maxxis Liberty, and even Toyo open country truck tires all flatted multiple times.
DEEZNUTS
Think weight, if you'd like to avoid driveline and suspension stress.
The consensus is that the more rounded profile is a little easier on the car.
14s or 15s both work fine, i would personally do the lighter overall package.
Keep your offset closest to 0 as possible. Think scrub radius, driver feedback, and minimizing leverage on components such as wheel bearings.
renodaytona
ITP Ultra Cross. Murrays run them and just did the Baja 1000 (860 miles) on the same set of tires. They have done this on several occasions.
thmterry
We have a group that is setting up a trip to do the whole APT in your opinion was it fun, would you do it again? Any tips would be appreciated.
rivrrts429
Arch Stanton...
This... I did the ITP Ultra-Cross on 14” Methods on my 18’ non-turbo. Least stress as possible and a great tire.
My buddy does the Baja Tour Packages. Basically Rosarito to Cabo all by dirt twice a month in RZR’s and this is what he recommended.
paradise
Spooner
Tensor regulators.
4 cars, thousands of miles each and no flats. I attribute it to the tires.
Reactions: TPC
HB2Havasu
Been running the 14”x31” Chicanes for the last 18 months with zero issues over approx 1500 miles. They are a DOT tire so the compound is a little harder, they still look like new and show no wear :D Just an FYI - I run the between 15#-18# psi to soften up the ride. With the 14” wheels it gives a little more cushion over 15”
bigriver48
Aloha mr hand
I’m using the Kanati Mongrels , 30”
grumpy88
Like mentioned by others I would watch total weight . Secondly good thing about a 15 inch rim it gives more clearance to the brake caliber in case a rock gets in the rim .
EPL
Most of the people I ride with are running the "Pro Crawler" tires . Between my 3 RZR's I gave gone over 12,000 and only one flat !!
I’m getting ready to change out on the wheels on my Ranger..
Currently running the M28 Ambush in 14’s with 30” Mongrels.
I think I’m going to end up going with the M26 Vibe or the Diesel at the bottom.
https://www.wheelpros.com/wheels/5323/5172/msa
Also going to try the new EFX tires but not sure which model is best for Havasu?
https://efxtires.com/
LakeMead Boater
Ran the 30" Tensor Regulator's on a 14" rim for multiple years and they were great. Just switched to the 32" Tensor on 15". Running a non-turbo XP4 1000.
The 32" weigh about 4.5 lbs less per tire compared to the 30". Also, the car handles WAY better with the 32's over the 30's....night and day difference.
There are a lot of good tires on the market, but I would definitely go with the 32's right from the get-go. Also, what c-land stated about the tires has also been true in our group rides. Most everyone is either on Tensor's or BFG KR2's...
Hammer
Did you lose any noticeable power loss with the 32’s? I want to jump up to a 32” tensor as well. (2016 rzr4 non turbo)
Lunatic Fringe
15" wheels with Arisun Aftershocks. I have been happy with them so far. Good ride, good traction and decent wear.
Don't do 0 offset, go with 5-2 offset with 7" wheels.
LakeMead Boater
Not that I noticed at all. The car just handles way better and goes through the big stuff significantly faster. If anything, the car might feel faster because it's easier to drive
Hammer
May put my 30” x 15 tensors up for sale then . Thenks
throttle
c ya on da lake
I ran the BFG’s for a year or two, they were without a doubt strong, durable and very reliable, however I will add they were heavy.
I have been running the Tensor regulator lately and can’t say anything negative about them. I run them on the street, dirt, rocks and washes in havasu and sometimes Parker. They have far exceeded my expectations!
Stick with 14x7s Try to go for a light wheel. Go with a 6+1 offset if you want the same width you have now. 5+2 still works well and will widen the car but don’t go for any more offset than that.
30 in is the dial in size for the non turbos.
I just put on Maxxis Liberty 30x10x14 on mine, they are awesome, ride well, are quiet, and are wearing great.
The STI HD9 is about the same weight as a Method beadlock, and just over half the price.
STI Chicane and ITP Ultra Cross are both supposed to be very good as well.
SHOCKtheMONKEY
How are those Liberty (ies)? in the sand?
That's what I was leaning towards until I was able to get five Racelines and Aftershocks for $1k.
riverroyal
I heard they are good with low air
Great street tire! Perfect in havasu
Bigbore500r
Still on the stock clutch setup?
77charger
My boss has a non turbo 2 seater he runs the mongrols does a lot of desert miles near Blythe been great for him clutch is stock. He used them in sand too just aired to about 8 pounds.
cakemoto
I was checking out cst at the show today.anyone run them?
Hammer
Mmmmm , BB500 needs those!
I have a set of 5 with only two or three trips on them they are practically brand new. Maybe 50 miles on them tops
