bbc 454 build
partie4evr
hi my name is chris and i have a 1974 chevy 454 with a 4 bolt main that i will be putting into a 21 foot schiada river cruiser v drive . i have built many engins before but this will be my first venture in v8 i used to haave a sandrail that had a vw in it . i would like to get around 900 hp out of it .so pretty much what i would like to know is how would u guys do it i have about ten g to spend on it . i am open to turbo and blower options whaat brand of parts would u use cam lift head size u know all that good stuff thank you very much in advance for your time and help have a great day .
obnoxious001
Engine building character
I sent you a PM over on PB,, think it has my phone number in it.
wrighton
Several things to consider. Going blown or turbo, you want to make sure you invest in some good internals and to make sure everything is clearanced correctly for a marine engine.
Lets face it. We dont want just a 900HP engine, We want a 900Hp engine thats going to be reliable and live.
there are several great post by obnoxious on here showing a marine engine build.
Looks like Barry has sent you his number. I would start by a call to discuss your options and good luck with your build.
racerden
Boat #197
Good luck Chris. If you have a good seasoned block with 7/16 rods and a steel crank, you should be able to find used turbo bolt-on's out there. The 10K # you threw out is entry level however used properly, it can fly...just barely. Be sure to invest huge in your heads basically starting with all new valves & springs if you choose turbo/blown applications. If you do chose a TT setup start with the Engle TC-7 cam, flat tappets etc. Good cam & grind for just about everything you want. Listen to Barry.
DV
