Another DIY fail
caribbean20
Got this vacation joint and the few times we use it, something always needs fixing. This time it was a burning smell which we traced to this outlet. I hit the circuit breaker for that bedroom expecting all electricity would be off. Figured no need for the multimeter. Well, you know how that usually works. I knew something seemed fishy but proceeded, nonetheless, albeit cautiously, with the wife yelling “just call an electrician!”
It was just a little jolt, no harm, no foul. Net, net, I learned of a valuable new tool from the electrician, called a “noncontact voltage stick tester.” I just ordered 2 from Amazon 😳
Those things are great,I have 2 of them myself
SoCalDave
I never kill power on 120 circuits when working on them. Now 240 and for sure 480 I always power down and test before proceeding. Been hit to many times by 480 in my earlier years and learned my lesson.
HBCraig
That's all we use on our tower cranes. 480, 3 phase
poncho
Got a 480 tickle once, not cool.
TrollerDave
Glad you’re ok.
Always check for voltage. You never know if the breaker is bad and doesn’t completely open.
That outlet looks rusty and crusty, was there a water leak?
Maybe consider changing that wire also.
ltbaney1
i have one those non contact testers as well. i still kill the power to what ever im doing and double check with the tester. i got brave a while ago and decided to change a few outlets upstairs and didnt kill the power. got buzzed and walked downstairs and killed the power. I have freinds that are career sparkys and they have told me they almost never turn off 110 power, but they are both terrified of skil saws, i can run a skill saw no problem. its all in what you are comfortable with.
RadMan
Throbbing Member
When I was just starting out was helping with some pump service. Grabbed a ground wire that was hot “hey Benny, this ground wire is hot”. Benny says no way and grabs it. We built a little trust that day😁
SoCalDave
Most of my career was in heavy manufacturing, plastics to be exact. Most of the plants I oversaw were 480vac/3ph. Main panels were anywhere from 4,000amp up to 10,000amp. My last employer we had 4,000amp main and our average electrical bill was $78k per month. 😲
SoCalDave
35 or so years ago I had an acquaintance in Toronto, Canada that had his own plastics manufacturing plant. He built it from the ground up and was getting very successful with his business. He had bought 2 new injection molding machines and was in the process of connecting the power supply (408vac/400amp feed) to one of the machines. He was in the process of stripping the main feeds at the machine and got a anticipated phone call so he went to his office for a few minutes. when he returned to finish his work he grabbed the bare end of a cable and it electrocuted him killing him instantly. Apparently someone had went by the main panel and energized that feed as there were no LOTO implemented and they never found out who had did it. Since that time I learned to ALWAYS do the LOTO procedure. After that any employee on my team that didn't follow SOP were terminated. I was not going to be the one to tell their spouse/family that they had lost a loved one. Fortunately I only had to let one guy go due to this rule.
Taboma
During my damn near 50 years rising up through the "Sparky" ranks, I like many of my peers, have worked various voltage circuits from 120V through 480v hot, but only due to extenuating circumstances and just being lazy or chest pounding rights wasn't one of them.
On my crews I demanded professionalism, not reckless stupidity and often it's the reaction to the shock, like striking an immovable object or worse, falling off a ladder, that can result in an injury.
I've explained at length in previous posts why 120V is so dangerous and what it can cause your body to do involuntarily and how that can easily result it death. I won't bother to repeat it.
If you take 120V between your callused fingers, no biggie, you take it across your chest, or arm to opposite leg or bare foot, good luck.
If you use a non-contact tester, the first thing you should do before using it is to test it on a known 'Hot Circuit', this will confirm two things --- A. You haven't forgotten to switch it on B. It still works since the last time you put it away.
Taboma
That damage appears to be very old and something that festered over a long period of time as a self-fulfilling route to eventual certain failure. That's normally caused by a loose wire connection, or loose socket blades with a significant and prolonged load. Like a woman's hair blower as those damn things are hard on receptacles due to the high wattage and movement of the cord itself.
You more than likely tried to remove it hot resulting in a dead short since so much insulation has been burned off or fell off because it's so brittle --- did it melt the ground wire off, I don't see one ?
My lovely wife cooked two over a series of years with her hair blower. In my new house I wired, I installed 20amp circuits and 20amp HD industrial receptacles at the locations she pointed out she'd be drying her hair. Those damned things are so stout it takes two hands to plug and unplug, but they ain't blowing up. 🤣
Good eye. 👍🏼
