A small rant about electronics installation in marine equipment.
MPHSystems
Hallett 240
As noted in a recent thread, I’m new here but in the last few month I have re-wired, some of my boat, My trailer and just this weekend, the stereo.
I am at a complete loss over the abundance of tomfuckery saturating aftermarket marine related wiring installations. I’m not even going to bring up scotch locks but seriously, whiskey tango foxtrot over? Not talking about the original wiring harness, 20 years old+ has stood the test of time and is still in good condition.
I’m talking about all the jacked up shit that so called professionals have done over the years. I probably should have taken photos but you’ve all seen the zip tied bundles of spaghetti. It’s not just the poor workmanship, it’s the poor design. Why would you run a separate #4 for each amplifier power and then have all the amplifiers share the same #4 ground? Why would you fuse the ground wires? Why would you take the time to run new speaker wire and use wire so cheep that RadioShack rejected it for the free wire they included with the discount speakers?
A few observations:
1) Every power wire needs to be fused, close to it’s power source.
2) By the time you are done, there should be no exposed energized metal or wire, as opposed to lots of it.
3) The only use for drywall screws is for hanging drywall; There is no drywall on a boat.
4) Just because you bought 100 feet of wire doesn’t mean you have to use 100’ of wire. You can cut it.
5) Scotch-locks, not even once.
6) It actually saves time to slow down and make things neat.
7) Every amplifier needs at least 3 screws to hold it in place, preferably 4 screws but never just 1.
Liquidkroozir
I'm a retired GM Auto Tech some of the repairs done by the "Proffesionals " that I worked with were absolutely appalling and they knew better. Thats also the way they would fix their own stuff. Some people are just not capable of quality work. then there are those who are DIYers that do awesome work.
Warlock1
I am the same as you. Hate garbage wiring, just plain laziness or cheapness. This is how I did it. This was before I put liquid tape on all of the positive connections. This particular boat had three amps hence the 3 CB.
Kachina26
Inmate #RDP158
When I worked at a GM dealer, we had a guy we called Scotch lock Tony. We were getting his comebacks for months after they fired him.
