87-91 bronco transfer case?
FCT
Anybody have a manual borg Warner 1356 to bolt up to a AOD laying around? Need the shifter and linkage as well. Wanting to convert my electric one over to manual.
Bakotrash
I will ask my brother, he may have something laying around.
Reactions: FCT
dread Pirate
Pretty sure I have one under a F350 at the shop. Not sure when I can get it out though?
Reactions: FCT
FCT
Thanks guys. It’s not a rush. It’s just some thing I want to do. So if it takes a minute to get it, I’m not worried about that. Let me know what you have. You can text me pictures as well if that helps.
9512369113
dread Pirate
9512369113
I'll go crawl under it and make sure its the right one for you. 7.3idi with a AOD should be the same case.
Reactions: FCT
FCT
Awesome thanks. I can shoot you a picture of mine later if that helps.
Ultra...Good
I know someone that would likely have one, but shipping might get ya.
dread Pirate
This what you're after?
JL95
I wanted a shiftser so bad when my electronic shift TC didn't function in my 87. Had the shitty auto hubs as well.
FCT
it’s worth a shot? Where’s it coming from?
It’s hard to tell if that’s the same in those pics. I’ll attach a few of mine.
That’s exactly what mine has and I want to swap it all out. Not to mention mine if full of electrical demons so if I want 4wd at the moment I have to crawl under and pop the motor off and manually put it in 🤣
dread Pirate
It's a 13-56 with a lever. I assume the bolt flange to the trans is the same? Trans has been leaking for awhile it seems. 😂
Ran fine when wrecked. Guy hit a redwood tree which moved the right frame rail to the middle of the truck. If you want it I can get it out this week and figure out how to start getting it south. Sacramento after Christmas would be easy, or Irwindale in late January if you're not in a hurry?
Great looking Bronco!
Reactions: FCT
dread Pirate
Actually looks like the flange that bolts up has a mount on mine, but is a removable section which should match your trans? Anyone else know these units better?
Edit; Looking at pics on a larger screen. I'm pretty certain the bolt pattern is the same. Just had me thinking backwards for a minute.
Reactions: FCT
FCT
I’m not sure. Here is a picture that shows the bolt pattern. I can’t really tell what yours looks like in the picture. Maybe this helps..
FCT
And I can’t imagine a redwood tree is very fun to hit🤣 Hopefully the guy was all right.
dread Pirate
I'll get my son to pull it off this week and double check everything. I think we've got you a case though.
  • Love
Reactions: FCT
FCT
Awesome. I appreciate that. If it’s the right one I have no problem waiting until January to grab it. I am in no hurry.
dread Pirate
Ill take some pics of the truck. Had 6 girls and himself . 2 heads hit the windshield, one girl went through the passenger window and the girls in the back seat made the front bench look like a taco. Fortunately they were only going 30ish and the one girl only needed a few stitches.
  • Wow
Reactions: FCT
hman442
A guy might look at Advance Adapters or Novaks websites. They have a lot of info & identifying photos/drawings to help make sure what's what.
FCT
But he had 6 girls! 🤣🙌
Ultra...Good
View attachment 1304609 View attachment 1304610 View attachment 1304613
Wagner auto. 17157324929, Marinette wi, 54143. Bruce Wagner. guy is un godly busy and for good reason. anything ford, I go thru him.
Reactions: FCT
dread Pirate
Sorry we had some bad weather and I kinda forgot about this. I'll get it out of the truck this week.
