33C to LS Style Throttle Body Cable Adapter
n2otoofast4u
I am running a Motion Race Works TB and need to be able to adapt a traditional 33C cable to it. I have looked on google with little success, hopefully there is someone here that has done something similar? The TB is mounted to a billet Holley Ram. Pics for reference. This is all in a jet boat. Maybe @bonesfab
4-30FT-Yamaha-33C-Marine-Throttle-Control-Cable-Boat-Outboard-Control-Lever-Cable.jpg_Q90.jpg_.webp
bonesfab
Make a lever you can bolt to the billet linkage plate. Extend it out a bit for more leverage and less light switch throttle. Just drill and tap that plate where the cable was supposed to wrap around, The one I did inmy buddies boat had a steel plate so I just welded a lever to it.
lf2
Control cables in santa fe springs can make you a 33c at the pedal side and a cable with the little end on the throttle body side.
Havasu Surfer
The brain trust on RDP is pretty phenomenal and worth its salt.
